Запускаю игру, а он мне пишет это:
JA: v1.0.0.0 win-x86 Aug 5 2003
Initialising zone memory .....
----- FS_Startup -----
Current search path:
D:\Jedi Academy/base
0 files in pk3 files
execing default.cfg
execing jaconfig.cfg
couldn't exec autoexec.cfg
...detecting CPU, found Intel Pentium IV
------- Input Initialization -------
Skipping check for DirectInput
Joystick is not active.
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
--- Common Initialization Complete ---
Working directory: D:\Jedi Academy
PlayCinematic(): Failed to open "video/openinglogos.roq"
Initializing OpenGL subsystem
...initializing QGL
succeeded
...setting mode 6: 1024 768 FS
...using colorsbits of 32
...calling CDS: ok
...registered window class
...created window@0,0 (1024x768)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...35 PFDs found
...GLW_ChoosePFD failed
...GLW_ChoosePFD( 16, 24, 0 )
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (6)
...setting mode 3: 640 480 FS
...using colorsbits of 16
...calling CDS: ok
...created window@0,0 (640x480)
...GLW_ChoosePFD( 16, 24, 8 )
...35 PFDs found
...35 PFDs found
...WARNING: could not set the given mode (3)
...shutting down QGL
...unloading OpenGL DLL
----- CL_Shutdown -----
GLW_StartOpenGL() - could not load OpenGL subsystem
В чем проблема, кто знает?
