<span style='font-size:8pt;line-height:100%'>
- Код: выделить все
[+] - Added [*] - Fixed/Changed [-] - Removed
2.52
[+] !!! Official AMIP IRC channel: irc.freenode.net
#amip
[*] New default presets
[*] !!! Automatic announcement is disabled now by
default
[*] Enable IRC option renamed to Announce
automatically because it's what it does now
[*] Options redesign (and File Chooser is added now)!
[+] %rawlen - raw file size as returned by ftell
[*] fixed 0 bitrate for flac and ape files (#04003)
[*] Updated FLAC to 1.1.1
[*] Updated zlib to 1.2.1
[*] Fixed the potential null-pointer during the locale
initialization (fatal error during initialization)
[+] ! /dde mplug announcesong N X - announces song N
by invoking preset X (1..5)
[+] ! /dde mplug announcesong N - announces song N by
invoking current preset
[+] ! /dde mplug announce preset N - same as announce,
but use preset N (1..5)
[+] ! /dde mplug announce - will announce current song
to mIRC using current preset (FINALLY!) Works even
if IRC Integration is disabled
[*] Fixed conditional $-functions
[*] iTunes: all memory leaks should be fixed now
[*] iTunes: options dialog can be invoked in the AMIP
Visualizer stub (round Options button on top-
right)
[+] iTunes: you can now quit without warning
[*] !!! iTunes 4.7 or later is required to run
[+] In addition to /flash(LAMP) command introduced in
2.48 there is now the same command but with
extended syntax: /flash(NUM,0,200,5) - will start
flashing NUMLOCK with the initial delay 0, in each
state (ON/OFF) lamp will be 200ms and will flash 5
times
<a href='http://amip.tools-for.net/index.php?content=load&file=amip_foobar07b.zip' target='_blank'>Download (554 kB)</a>
</a>| <!--coloro:#009900--><span style="color:#009900"><!--/coloro--><a href="http://irc.run.net/Pix/ircmap.txt" target="_blank">RUSNet:</a> #miranda #foobar2000 #mozilla<!--colorc--></span><!--/colorc-->
</a>
