Notes:
A new feature of this release is more ways to get Miranda and components.
1. There is a small web installer which will download selected packages once you
have selected them in the setup application (-web)
2. An installer which contains everything and useful for people
who want to do offline installations (-full)
3. A ZIP archive containing Miranda and components
4. A 7z archive containing Miranda and components
If you are in doubt what to download, get the web installer.
Changes:
* New in 0.4.0.1
Miranda:
- Support for Windows 95 (message loop was broken)
- Now waits upto 1.2 seconds if a connection attempt was made less than one second ago.
Helps with XP SP2 which has a lower connection limit per second.
- User details could show invalid local times
- Buttons didn't always draw their icons the correct size
- memory leak in send/recv file dialogs, email menu item, font leak in buttons
- Find/Add trims any spaces from emails and user IDs whilst pasting
- Idle didn't change back to online message if going from autoaway back to online
- Added too many blackslashes when sending a root directory to a contact
Database:
- Writing a string setting over another setting type can crash
- Added back default profile support (incl AutoCreate)
- Cached writes only do actual writes if needed
- Static fetching of BLOBs didn't work correctly
Contact List
- Running a profile that is locked will show the window for the Miranda running it
- Right clicking on a contact crashed if no menus were added
- Ask before deleting groups in the CList
- When drawing text, ignore linefeeds in nickname text (fixes forced next line bug)
- memory leak in contact list, tray icon
- Limit preference reading during resizing
- Added back 'click to focus' transparency
Message Window (SRMM):
- Files can be Drag&Dropped into a contact's message window and sent to them
- Position of divders didn't get saved if the avatar icon was displayed
- Message window strangeness if a message failed to be sent
- Disabling avatars via options hides existing avatar icons in dialogs
- Status modes didn't display correctly if built with Unicode
- Smoother window resizing
- Hide istyping notifications if contact goes offline
- Can now show seconds in timestamps
Chat:
- Icons in statusbar are changed when proto icons are updated
- Relative paths for chat.dll logs
AIM:
- Added a menu item for private messages via aim group chat UI
- Invites crash
- Show whisper messages as notices in aim group chat
- AIM now uses chat.dll for group chat
- New icons from valkyre
- Better handling of AIM: links
ICQ:
- Main server loop could malfunction causing 100% CPU usage
- Associated avatar info isn't cleared if the server sends back an error
- Do not move contacts to non existant server groups
- Error in error reporting code (hm.. )
- Better handling of offline messaging
- Detect UTF8 in auth messages
- If auth is from a contact on your list it will show it as a local request
- Added hidden setting to disable sending unicode to Trillian/IM2 per contact
- Actually obey rate limit when doing user info and status message requests
- Added better UTF8 detection
- Handle "sign on warnings" to login even if they are issued
- Don't try and store avatars bigger than protocol level limitations (could crash)
- If a contact in the server list has no nickname, query it from the server
- Server can intentionally send random garbage as an avatar, only set if its in a known image format
- Network string is now Translate() able
- Could crash if server returned string was reported wrong size
IRC:
- Don't crash if handling a faulty MODE +/-k or i/-i command
- Don't steal focus if joining with /JOINM
- Add network name to notices
- /AWAY can not be used from a perform buffer
- Handle 'connecting whilst dying' suitations
- Improved user status detection
- Failed to load if Windows DEP was enabled
- Online notification stopped working after manual /WHO
MSN:
- MSN Personal messages (aka status messages)
- MSN V7 support (logging in via MSNP11)
- Messages could get lost (line ending issue)
- Better 'invisible' support whilst using MSN v7
- Changes to how MSN hotmail website is opened
- Now shows you if a contact is using WebMessenger in the user details
- Group renaming now ignores case when looking for existing groups
- Keep alive shuts down better
- Keep alive thread could cause crash on exit (hah irony.)
- PCs with multiple IPs are handled better during P2P
- Actually knows what the 'Occupied' status message is (wtf..)
- If deleting a contact add them to the block list
- Better handling of empty contact list sent by the server
- memory leak in file transfers
Jabber:
- Jabber group chat is now implemented via chat.dll
- Messages to a disconnected jabber conference caused a crash
- Improved Jabber resources handling
- XML specials in add contact
- Better handling of vcards
- Better status message monitoring
- A user can appear more than once in a group chat roster list
- Doesn't show chat items in the group chat menu
- Contacts renaming is handled better
- Shutdown code is now thread safe
Yahoo:
- Custom messages support
- Better support for status messages
- Added gamer status, shows what game a contact is playing if any.
- Better handling of status change requests whilst connecting
- Logging in Invisible actually works
- Authorisation issues if contact is on list but a temporary
- Authorisation issues if a contact was added via an event (such as search)
- Added support for mTooltip photos
- Changes in popup support, colour changes now work better
- If away message is empty it will use a standard away message
- Contacts with custom messages are shown as 'away' rather than occupied
- Custom message whilst idle is handled better
- Going 'online' via setting another status did not work as expected, now also uses that status message
- Can rename files during file transfer
- Rejection of requests done whilst yahoo is offline (like add)
- Check for password before using it internally
<a href='http://heanet.dl.sourceforge.net/sourceforge/miranda/miranda-im-0401-full.exe' target='_blank'>Скачать</a>
