<a href='http://hell.at.eu.org/forums/board.php?id=8' target='_blank'>TabSRMM 0.9.9.7</a> (358 кб)
<!--QuoteBegin-"Nightwish"+--><div class='quotetop'>QUOTE("Nightwish")</div><div class='quotemain'><!--QuoteEBegin--><span style='font-size:8pt;line-height:100%'>! re-enabled the "show multisend" menu bar item.
! export/import themes now show the appropriate file selection window (open/save as)
! fixed send on shift enter.
! "Flat message log" now tries to remove static edges from ieview and message input area aswell.
! detecting IEView on startup didn't work with some configurations.
! When "send formatting info" was active in the non-unicode version, additional
linefeeds were sent at the end of each message.
! new send mode - force ANSI. When enabled, messages will be sent as pure ansi, using the current codepage. Useful when the client of your buddy has troubles receiving unicode messages. This setting is a "per contact" OVERRIDE and WILL STICK even if you close the message window until you deactivate it.
This has only an effect in the unicode version of tabSRMM - the non-unicode always sends ANSI.
+ the protocol menu is back. At the moment, it has only one submenu for configuring the message log. It is now possible to switch between rich edit and IEView "on the fly" while the message window is open. Please note, that these settings are saved to the contacts db record, so you can now override the message log being in use on a "per contact" basis.
Example: You have set the default option to use the IEView plugin (message log options). You can now override this setting for a specific contact and force the default message log. (or vice versa, of course).
+ made hotkeys translateable. Please refer to the translation template included in the archive to figure out which strings need to be translated. The hotkeys are at the very end of this file.
+ new hotkey - Alt-T (default). Toggles toolbar quickly..</span><!--QuoteEnd--></div><!--QuoteEEnd-->
</a>| <!--coloro:#009900--><span style="color:#009900"><!--/coloro--><a href="http://irc.run.net/Pix/ircmap.txt" target="_blank">RUSNet:</a> #miranda #foobar2000 #mozilla<!--colorc--></span><!--/colorc-->
</a>
