Сабж.
<a href='http://www.fforum.ru/index.php?showtopic=19861&hl=' target='_blank'>Начало темы. What's news</a>
<a href='http://www.sendspace.com/file/d2aoyz' target='_blank'>Скачать form SendSpace (1,600 Kb)</a>
14.12.05 Fixed: 2 Total Commander instances, left mose selection mode. Drag&Drop files/dirs with right mouse button between the two, create link -> links with wrong names created (.lnk extension missing)
14.12.05 Fixed: Explicitly set focus to current file list before closing the quick search dialog, to fix a bug in WindowBlinds 5
14.12.05 Fixed: When viewing single files with F3 or Alt+F3 and the local file already exists, use new naming scheme file.txt -> file.000.txt instead of just file.000 (e.g. for lister plugins)
11.12.05 Added: U3 support: Internal functions to ensure that TC shuts down in all cases when removing an U3 USB stick
09.12.05 Fixed: Included new unacev2.dll (security bugfix)
09.12.05 Fixed: Don't save selection within a tab when switching away from a locked tab with dir changes allowed (except when in the base dir of that tab)
30.11.05 Fixed: FTP: replace special chars;:@&=+"#%<> by %hexcode, because some HTTP proxies (Squid!) dislike these characters in URLs
30.11.05 Fixed: FTP: trying to download very long name can cause access violation
29.11.05 Fixed: Some colors incorrect when using white on black text
25.11.05 Fixed: By mistake, all content plugins without a detect string were loaded with totalcmd! <- solution: save empty detect string to ini too!
23.11.05 Fixed: Some right to left dialogs (Hebrew, Arabic) were not shown correctly, e.g. search in plugins
22.11.05 Fixed: When adding files to a packer plugin archive with different extension than registered, TC didn't ask for overwrite. Changed plugin interface version to 2.11 to reflect this change.
22.11.05 Fixed: Status path shown incorrectly in custom columns view with LongInStatus=1
13.11.05 Added: For admins: Under HKEY_CURRENT_USER\Software\Ghisler\Total Commander\configuration, add allowed (type string) and/or RestrictInterface (type DWORD) to restrict user options. The value will be combined with the value in the ini file (the more restricted wins)
30.10.05 Fixed: Synchronize dirs with FTP: use UTC for MDTM command
30.10.05 Added: Multi-rename tool: Replace characters (returned by plugins) which are not allowed in file names by underscores or dots
21.10.05 Fixed: Ctrl+Q quick view panel: With some lister plugins like hpg_ed, F3 invoked both find next (desired) and the lister (not desired)
18.10.05 Fixed: FTP sync: additional check for ESC during upload+download
18.10.05 Fixed: Synchronize dirs: Increased the default widths of the size columns a bit (user request)
18.10.05 Fixed: Search in plugins: Go to file not working if the file name or path contained a forward slash
16.10.05 Fixed: Background transfer manager: speed limit not working when copying multiple subdirs
16.10.05 Fixed: Background transfer manager: aborting copy function not always working
11.10.05 Fixed: Disallow the creation of directories ending with spaces, e.g. "a / \ "
11.10.05 Added: Allow to delete directories and files which end with one or more spaces!
09.10.05 Fixed: Memory error in compare tool with some big files
28.09.05 Fixed: When using Letters with search dialog as quick search mode in archives with Ctrl+Q, then going to an image file can cause an access violation (because the quick search dialog is hidden by the unpack dialog)
27.09.05 Fixed: In double byte languages like Chinese, characters in zip/rar with second char '|' were shown incorrectly (because '|' is normally illegal in file names)
27.09.05 Fixed: Make FTP client work with FTP servers which return a forward slash after a directory name
27.09.05 Fixed: When browsing virtual folders, try to get the name in various ways (first for parsing, then in folder, then normal)
27.09.05 Fixed: F3 on mp3 file marked "Text" instead of "Image/Multimedia" in lister's menu
23.09.05 Fixed: Unzip: If zip file contains invalid (0) date/time, don't set it on extraction
21.09.05 Fixed: Lister: Wrong text copied in first line (unicode mode and utf8 mode)
18.09.05 Fixed: Wrong display under the following condition: Vertical arrangement, two drive button bars, then switching color depth (e.g. 16 bit -> true color)
18.09.05 Fixed: Custom columns view: "list index out of bounds" error if both sides only show name+ext, and the column width is adjusted by mouse
18.09.05 Fixed: Dual screen mode: Double click on word in Lister only selected the word on screen with positive coordinates
18.09.05 Fixed: Win9x only: Renaming not working in mode singleclickstart=1 if the mouse was moved over the file list during renaming
16.09.05 Fixed: Clicking on panel title while quick view was active did not activate the RTF viewer or a plugin inside of the quick view panel
16.09.05 Fixed: On Ctrl+U, do not set swapped tab title to locked tabs
13.09.05 Added: Command line parameters for uninstaller tcuninst.exe for silent uninstall: /r repair, /0../7 unstall. Sum of: 1=desktop icon, 2=context menu entries, 4=all settings files
25.08.05 Fixed: Button bar : no icon shown if path contained a comma
23.08.05 Added: Optimize unzip: open archive once at the beginning and keep open (necessary because of a bug in Windows XP SP2, where CloseFile over a network takes up to 2 seconds!)
10.08.05 Fixed: Synchronize dirs: Copy direction problem when synching between dir+zip in asymmetric mode and unchecked files
09.08.05 Fixed: Tree functions and creation of dirs failed if Alt+F10 tree contains paths longer than 259 characters
29.07.05 Added: On Ctrl+PageDown, TC now searches the first 512 kbytes for a valid archive header. Reason: The RAR unpacker will support themes which can contain a big uncompressed background bitmap in the unpacker...
06.07.05 Fixed: Copy speed limit wasn't enforced when opening the background transfer manually and adding files for copying AFTER checking the speed limit option
06.07.05 Fixed: Clicking on "*" button in the inactive panel added/removed the wrong directory (from the active side!)
06.07.05 Fixed: Internal unzip: forget password after operation
06.07.05 Fixed: Built-in English menu: In the "Mark" menu, two menu items had the same hotkey
06.07.05 Fixed: Changed behaviour of FTP server define dialog: Alt+Shift+Enter during a connection will keep currently used server type. OK will apply the new settings, Cancel will revert to standard type.
05.07.05 Fixed: Button bar: If parameter starts with '?' and contains one of the list parameters like %L, the temporary list wasn't deleted if the user clicked 'cancel'
05.07.05 Fixed: Ctrl+Shift+U (Swap all tabs) not working properly when a tab with "locked but dir changes allowed" was an active tab, and this tab was showing something else than the locked root dir
05.07.05 Fixed: Tab with "locked but dir changes allowed" was lost (deleted) when it was showing a search result while closing the program (only if the tab was inactive)
05.07.05 Fixed: Switch between tabs with comment view and tree view not working correctly
05.07.05 Fixed: Switch from search result view to tree view didn't change tab title from "Search result" to e.g. "c:"
05.07.05 Fixed: Don't switch from search result to full view when choosing Show-Full while showing comments in search result
Для версии Total Commander 6.54 beta 3
03.01.06 Fixed: Problem with hanging download if ftp server went offline in the meantime
03.01.06 Fixed: Various small errors in English and German help files
03.01.06 Fixed: Irfanview/Xnview not closed after it was loaded in the background for displaying of images or thumbnails (only when new extract method used)
03.01.06 Fixed: Directories were shown under wrong parent in Alt+F10 tree view when SortUpper=3 was used -> fallback to SortUpper=2 for tree
03.01.06 Fixed: Upload in background: Rename doesn't work when a file with the same name was detected
03.01.06 Fixed: Changed function called when displaying WMF or EMF files, seems to cause no more crashes
01.01.06 Fixed: Sometimes thumbnail extra fields could be shown in custom columns view with very long names in archives
01.01.06 Fixed: Could not decode SQX (binhex-coded) file when run length compression was used already in the header
30.12.05 Fixed: Don't show WMF (windows meta file) and EMF (enhanced meta file) images in Lister and thumbnails view, because of buffer overflow bug in Windows DLL. Once yor system is patched, you can re-enable them: wincmd.ini [Configuration] WmfAllowed=1
30.12.05 Fixed: Again duplicate hotkey in internal English "Net" menu
25.12.05 Fixed: Switching from custom columns view to thumbnail view and back -> horizonal scrollbar was lost
25.12.05 Fixed: Incorrect tooltip for button bar button command cm_LeftThumbs when menu contained only cm_SrcThumbs
23.12.05 Fixed: When aborting move or delete function in plugins, don't call FsRemoveDir for parent directories
23.12.05 Fixed: Directory hotlist (Ctrl+D) was not case-insensitive for non-English characters like accents or cyrillic
Для версии Total Commander 6.54 beta 4
08.01.06 Added: Set MODE Z compression ratio (0..9) for uploads in wcx_ftp.ini [General] zlibratiobin=3 or zlibratiotxt=3 (separately for binary and text).
08.01.06 Fixed: FTP upload to a server supporting MODE Z fails with "error decompressing data stream" when uploading via a Cisco PIX 7.0.4 firewall (the pix doesn't support compression rate 1) -> use default rate of 3 now
08.01.06 Fixed: No thumbnails shown for folders on XP (they were disabled because they can contain WMF files) -> re-enable if patched gdi32.dll found
06.01.06 Fixed: Access violation when invoking cm_DirectoryHotlist via AutoIt without setting the lparam parameter to 0 (only when history+hotlist buttons disabled)
05.01.06 Fixed: In WatchDirs mode, files could disappear from the list by mistake
02.02.06 Release Total Commander 6.54 final
01.02.06 Fixed: Ctrl+C in lister still copied a space too much in some cases
01.02.06 Fixed: Wrong cursor movement in WatchDirs=5 mode
Вернуться в Warez&Cracks Request
