An@t0ly писал(а):так что если и ставить то только после SP1, а он будет обязательно.
ага, тогда эта новость для тебя:
<!--quoteo--><div class='quotetop'>Цитата</div><div class='quotemain'><!--quotec-->Windows Vista SP1(codenamed Fiji) hotfixes appear on Microsoft's site
vistasp1.net has posted links to six hotfixes set to appear in Windows Vista SP1 (Service Pack 1) codenamed Fiji. All six fixes can be obtained via Microsoft Support if you can prove that you are indeed having the problem listed. The site links directly to Microsoft KB articles that describe each problem in Vista.
929734 - You may experience problems after you resume a Windows Vista-based computer from sleep or from hibernation
929191 - IBM and Lenovo computers may take longer to start Windows Vista than computers from other manufacturers
929550 - When you connect a PCI ExpressCard device to a portable Windows Vista-based computer, the device may not work correctly
928188 - Ink programs may not work correctly on a digitizer in Windows Vista
929478 - After you use the Safely Remove Hardware option to remove a built-in optical drive from a portable Windows Vista-based computer, you may be unable to reconnect the drive
929577 - A Bluetooth device may no longer work correctly when you wake a Windows Vista-based computer from sleep
928253 - SATA optical drives are not available after you start a Windows Vista-based computer<!--QuoteEnd--></div><!--QuoteEEnd-->
Source : <a href="http://www.vistasp1.net/" target="_blank">http://www.vistasp1.net/</a>
