Морально я готовился к страшному, что с новой знаковой версии прога будет переписана по типу как ACDSee развивадась. Ан нет!
Что нового в 4: <!--quoteo--><div class='quotetop'>Цитата</div><div class='quotemain'><!--quotec-->Version 4.10 ( - CURRENT VERSION - ) (Release date: 2007-10-15)
- New PlugIn: Paint (Edit menu, Hotkey: F12, thanks to Matteo Italia!). It allows IrfanView to paint lines, circles, arrows, straighten image etc.
- Support for embedded color profiles in JPG/TIF (Properties->Viewing). LCMS PlugIn, thanks to Marti Maria
- New command line option: /advancedbatch (Apply advanced batch options to image). Allows many image operations, add text etc.
- Lossless JPG Crop added (Menu: Options or Thumbnails (batch mode))
- Added option to tag/mark files during browsing (window or fullscreen mode): Hotkeys: X = tag file, SHIFT+X = untag file, SHIFT+Q: show tagged files in Thumbnails
- Support for FLV format (Flash PlugIn, thanks to Remio)
- Histogram feature added (Menu: Image, Hotkey: SHIFT+H)
- Zoom calculation changed: relative, based on previous zoom value
- Auto adjust colors works with selections (Thanks to Andras Horvath, www.log69.com)
- Option to save values from "Enhance Colors" dialog
- New effects added: Green and Yellow eye reduction (Effects browser dialog)
- Option to keep current scroll position for the next image (Menu: View)
- Support for HDP/WDP format (Microsoft HD Photo, PlugIn)
- Save support for JNG format (Thanks to Pavel Demchuk)
- New GUI for batch/slideshow dialogs
- Custom selection dialog uses current selection at start, if available
- New compression options in PDF export (Thanks to ComSquare AG)
- New loading options for normal RAW files (Thanks to Sergey Fokin)
- Fullscreen options can be changed during fullscreen mode
- Browsing: if CTRL pressed, the file index increases/decreases by 5 (default: 1)
- 3 external editors are possible now (Properties->Misc 3)
- New option for Import palette: Use nearest color (Properties->Misc 3)
- Changes in print option Scale (original image size is used as input)
- New print option for multipage images: Print odd or even pages
- Some changes/optimizations in HTML templates
- CTRL+A selects the whole image in the main window
- Several PlugIns are changed/updated, please install the newest versions
- Some bugs fixed (IFF/PCX/JP2 loading, GIF animations, Palette import)
Version 4.00 (Release date: 2007-04-23)
- Improved Vista compatibility
- New display option: Center image in window (Menu: View->Display options)
- Toolbar skin option added (Properties->Toolbar)
- New Properties->Video option: Use DirectShow for playing (good for MJPG AVIs)
- New advanced batch option: Auto adjust colors
- "Enhance colors" can be now used on selections
- New EXIF dialog button: Show in Google Earth (if GPS data available)
- The EXIF dialog can stay displayed on screen
- Thanks to Dmitri Poguliayev for the new Vista icon!
- New Hotkey: CTRL + SHIFT + M = Show/edit JPG comment
- Some bugs fixed (Start folder, RLE BMPs, ANI loading)<!--QuoteEnd--></div><!--QuoteEEnd--> Ссылки по скачиванию: <a href="http://www.irfanview.com/download_sites.htm" target="_blank">IrfanView 4.10</a> // <a href="http://www.irfanview.com/plugins.htm" target="_blank">Plugins</a> / <a href="http://www.irfanview.com/skins.htm" target="_blank">Toolbar Skins</a> / <a href="http://www.irfanview.com/languages.htm" target="_blank">Languages</a>
