The Bat! 3.71.01
Сообщение Terrogen » Пн фев 20, 2006 8:21 pm
Известный почтовик обновился до The Bat! 3.71.01
Что нового в The Bat! 3.71 (по сравнению с v3.65.03)?
[ Легенда: ]
[ ! Существенное улучшение ]
[ + Добавленная функциональность ]
[ * Исправлена/изменена функция ]
[ - Исправлена ошибка (надеемся) ]
[+] Advanced search
[*] Search speed optimizations
[+] You can import addresses to the address book from X.509 binary certificates.
[+] Folder Maintenance stores previous operation checks
[+] The Bat! now works with Outlook Redemption DLL (http://www.dimastr.com/redemption/) for better importing from MS Outlook.
[+] Outlook Import and Exchange MAPI: added support for attached RFC-822-messages embedded as ATTACH_EMBEDDED_MSG.
[+] When importing addresses to the Address Book, you can select multiple files.
[+] Minor: cmdline parameter /MsgId:ref to open message with specified ref on startup
[+] Help button for the "Pick email address" dialog.
[!] Removed deprecated feature "Client-Server Mode"
[*] Better error logging for Exchange Server
[*] Better error logging for MAPI Exchange connections.
[*] Coloured sorting key column of the message list is back
[*] common folders now do allow setting the confirmation behavior and templates;
[*] Better mail retrieval for Exchange server.
[*] When working with Exchange server, The Bat! queries messages one-by-one.
[-] When importing messages from MS Outlook or retrieving from MS Exchange server via MAPI, transport message headers (RFC-822) weren't preserved for messages delivered by SMTP.
[-] Import from MS Office 2000 Outlook and earlier didn't work in The Bat! since version 2.05
[-] Better name resolution in Exhchange MAPI sessions.
[-] Exchange MAPI: The Bat! might consider some folders on Exchange server as not for email messages and could skip them during mail retrieval
[-] Exchange MAPI: incorrect number of processing folders was displayed during mail retrieval: The Bat! did also count empty folders
[-] Exchange MAPI: The Bat! did improperly calculate the total e-mail message count: non-email items like appointments or addresses were also added to the total number of e-mail messages to retrieve, although The Bat! did skip these non-email items
[-] Exchange MAPI: you can go to Account|Properties|Options and turn on "Verbose Log" to see which folders and items does The Bat! skip or process during Exchange retrieval
[-] Exchange MAPI: A dialog box should be displayed to prompt the user for the profile password, if required. Now The Bat! uses the following MapiLogonEx flags: MAPI_EXTENDED | MAPI_ALLOW_OTHERS | MAPI_EXPLICIT_PROFILE | MAPI_NEW_SESSION | MAPI_PASSWORD_UI | MAPI_FORCE_DOWNLOAD.
[-] Exchange MAPI: When verbose logging is enabled, when The Bat! skips non-email items, it displays the Message Class and Subject of these items.
[-] Exchange MAPI: The Bat! did calculate the number of skipped messages improperly.
[-] possible AV on exit, IMAP account
[-] When importing messages from MS Office Outlook, The Bat! didn't convert X.400 addresses to SMTP addresses. This opportunity is only available for Office XP, Office 2003 and later versions.
[-] The Bat! didn't import messages which had no bodies.
[-] IMAP: fix of duplication on synchro
[-] IMAP: moving to local folders
[-] IMAP: possible wrong encoding
[-] Minor: system hotkey couldn't be cleared
[-] "Edit personal certificates" button in Account Properties also works for CryptoAPI S/MIME implementation
[-] The filter condition "Time of ... is ..." was not storing minute values
[-] (#0005373) Content of message Memo as filter condition does not work
[-] (#0005302) "Create a formatted message" filter action is broken
[-] (#0005124) Macro %TO, %FROM & %SUBJECT doesn't work if field was previously set empty
[*] (#0005654) Create Filter dialog (menu: [Specials -> create filter): checkbox added to create a common filter
[-] (#0005620) deletion of qsearch-created tab not always removed filter
[-] (#0005619) Crop Button Macros
[-] (#0005610) Customiser: Shortcut items actually missing shortcut keys produced AV on exit
[-] (#0000767) It was not possible to set an empty name for iKey1000 token.
[-] (#0005569) Invalid focus position in S/MIME input password dialog
[-] (#0002252) Cursor not positioned correctly in Template editors (including Quick Templates) when you click with the left mouse button on the place where you would like to put the cursor.
[-] (#0005649) Under IMAP, color filters incorrectly color messages
[-] (#0005551) In CryptoAPI S/MIME implementation, if a certificate didn't have a CRL distribution points extension, The Bat! wrote that certificate revocation status is unknown and ceased to use this certificate.
<a href='http://www.ritlabs.com/ru/products/thebat/download.php' target='_blank'>страница загрузки</a>
+++Пользователям Home Edition рекомендуется обновить Языковой модуль.
Вернуться в Новости софта
