ACDSee 8 Pro
Сообщение Terrogen » Ср янв 11, 2006 12:03 am
Вышла Pro-версия известного вьювера ACDSee 8 Pro
<span style='font-size:8pt;line-height:100%'>Top Features in ACDSee Pro
Designed to inspire.
Lightning-fast RAW image previews.
Powerful RAW processing that gives you full control over your images with precision tools for adjusting white balance, exposure, sharpness, and noise.
Extensive support for RAW formats from Nikon, Canon, Konica-Minolta, Olympus, Fuji, and Pentax cameras. View the full list.
Full color management support for ICC and ICM color profiles.
Visual tagging feature allows you to quickly sort and select preferred photographs.
Integrated support for the DNG (Digital Negative Specification) RAW format.
Batch editing of thousands of photographs at once using multiple functions.
Fully integrated IPTC support for interoperability with PhotoShop Captions.
Watermark your photographs with graphics or text to reflect copyright and ownership laws, or to overlay business-related information on specific photographs.
The Shadow/Highlight tool allows you to brighten only the dark areas of a photo, or darken only overexposed areas, or do both simultaneously.
HTML album templates designed to suit your professional needs. Customize them by adding your contact information, company logo, or a look and feel appropriate for your business.
Customizable Browser layouts, short-cut keys, and metadata meet your personalized requirements and streamline your workflow.
Quick editing features that allow you to easily fix common lens distortions such as perspective, barrel, pincushion, and fish-eye.
A complete User Guide and tutorials that make sure you hit the ground running.</span>
<a href='http://downloads.acdsystems.com/en/acdseepro.exe' target='_blank'>скачать триал</a> 24.8 Мб. работает 7 дней <!--emo&:(-->[img]style_emoticons/<#EMO_DIR#>/sad.gif[/img]<!--endemo-->
Сообщение sm@rt » Чт янв 12, 2006 2:49 pm
Мне кажется уже не свежачок новость
Сообщение Elzor » Чт янв 12, 2006 6:02 pm
А мне кажеться что этот монстр давно уже что угодно только не вьювер. Перестал им пользоваться после 3 версии.
Elzor
Сообщение maxovt » Чт янв 12, 2006 8:13 pm
2sm@rt
На форуме уже было? Или только сейчас одобрили?
2Elzor
Аналогично. Какое-то время использовал как thumbnail-придадок к IrfanView, но после релиза 4-ки перешел на XnView.
А можно и Фотошопом картинки смотреть. <!--emo&:)-->[img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]<!--endemo-->
Последний раз редактировалось maxovt Чт янв 12, 2006 8:17 pm, всего редактировалось 1 раз.
Сообщение Terrogen » Чт янв 12, 2006 8:15 pm
2sm@rt
Pro-версия новость.
2Elzor
Веришь, оно летает :) Идеальный продукт.
А любителям бесплатных вьюверов я советую порассматривать картинку этак 5000Х6000 и больше в режиме подгонки под экран - там разницу и почувствуете - начиная от нездорового цвета, кончая такой же картинкой :)
Сообщение maxovt » Чт янв 12, 2006 8:25 pm
2Terrogen<!--QuoteBegin--><div class='quotetop'>QUOTE</div><div class='quotemain'><!--QuoteEBegin-->Веришь, оно летает<!--QuoteEnd--></div><!--QuoteEEnd-->Напомни-ка свою конфу. <!--QuoteBegin--><div class='quotetop'>QUOTE</div><div class='quotemain'><!--QuoteEBegin-->А любителям бесплатных вьюверов я советую порассматривать картинку этак 5000Х6000 и больше в режиме подгонки под экран<!--QuoteEnd--></div><!--QuoteEEnd-->Где сканы м арты можно покачать в таком разрешении? Эта маловата <!--emo&:wub:-->[img]style_emoticons/<#EMO_DIR#>/wub.gif[/img]<!--endemo-->
<a href='http://img454.imageshack.us/img454/6830/11256830470547cs5zw.jpg' target='_blank'>Изображение</a>
Сообщение Terrogen » Чт янв 12, 2006 8:44 pm
2maxovt
<!--QuoteBegin--><div class='quotetop'>QUOTE</div><div class='quotemain'><!--QuoteEBegin-->Напомни-ка свою конфу.<!--QuoteEnd--></div><!--QuoteEEnd-->
не помню <!--emo&;)-->[img]style_emoticons/<#EMO_DIR#>/wink.gif[/img]<!--endemo-->, год назад народ удивлялся и ахал, нынче же высмеивают уж <!--emo&:)-->[img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]<!--endemo-->))
<!--QuoteBegin--><div class='quotetop'>QUOTE</div><div class='quotemain'><!--QuoteEBegin-->Эта маловата<!--QuoteEnd--></div><!--QuoteEEnd-->
для чистоты - скрин твоего скана из субжа. Выложи скрин из твоего "другого" порошка. Хотя цвета убогие, только чистые, не полутонов, нихера нет - в пейнте на колене рисовалось.
<a href='http://img338.imageshack.us/my.php?image=clip1ay.jpg' target='_blank'>Изображение</a>
И про .raw ещё не забывай...
Ctrl+A
<span style='color:white'>Кстати, чуть не забыл... Я поставил субж, при инсталляции выбрал триал, а далее дело техники - вы видите ниже ссылку на руссификатор (!!!), который кидаете в директорию программы, выбрав тип файлов "все .exe", жмёте "apply" и вуаля - программа русская <!--emo&;)-->[img]style_emoticons/<#EMO_DIR#>/wink.gif[/img]<!--endemo-->
Пароль - fforum.ru
h_p://webfile.ru/741996]Имя файла - figovina.zip , размер 20 Кбайт
он будет доступен до 20.01.2006</span>
Последний раз редактировалось Terrogen Чт янв 12, 2006 10:35 pm, всего редактировалось 1 раз.
Сообщение maxovt » Чт янв 12, 2006 10:56 pm
2Terrogen<!--QuoteBegin--><div class='quotetop'>QUOTE</div><div class='quotemain'><!--QuoteEBegin-->Выложи скрин из твоего "другого" порошка<!--QuoteEnd--></div><!--QuoteEEnd-->Выложил: <a href='http://img191.imageshack.us/img191/8669/clipboardiv7jf.jpg' target='_blank'>IrfanView</a> // <a href='http://img295.imageshack.us/img295/1056/clipboardxn4ea.jpg' target='_blank'>XnView</a> // <a href='http://img295.imageshack.us/img295/4606/clipboardss0dh.jpg' target='_blank'>PictView</a><!--QuoteBegin--><div class='quotetop'>QUOTE</div><div class='quotemain'><!--QuoteEBegin-->год назад народ удивлялся и ахал, нынче же высмеивают уж<!--QuoteEnd--></div><!--QuoteEEnd-->А мне просто не верят, что такие еще бывают. <!--emo&:)-->[img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]<!--endemo-->
Последний раз редактировалось maxovt Чт янв 12, 2006 11:08 pm, всего редактировалось 1 раз.
Сообщение DruiD » Чт янв 12, 2006 11:12 pm
<!--QuoteBegin-Terrogen+Jan 11 2006, 03:03--><div class='quotetop'>QUOTE(Terrogen @ Jan 11 2006, 03:03)</div><div class='quotemain'><!--QuoteEBegin-->24.8 Мб
[right][snapback]196703[/snapback][/right]
чтобы картинки смотреть? Или к этому делу нужно подходить серьезно? :)
По мне, так и тотал сойдет. Эскизы + quick view - что еще для счастья нужно?
Сообщение Terrogen » Чт янв 12, 2006 11:14 pm
2maxovt
а теперь открой их в табах и сравни - PictView ещё куда не шло, а IrfanView и XnView проигрывают, ИМХО - особенно красные шапки посравнивай - чистоту цвета и насыщенность. А если в АСDsee ещё внедрить профиль цветового пространства "норитцу" (половина минилабов), то реально можно увидеть именно то, что ты получишь на фотобумаге при печати без коррекции, которую так не любят в наших фотосалонах :) Вопрос в том, нужно ли это обычному юзеру, скачавшему воллпейперс с сети :)
И по мелочам минусы:
НЕЛЬЗЯ в XnView
- переставить картинки в папке по своему порядку, а потом все переименовать
- порядок можно изменить в окне переименования, но там не видно картинок
(Мне привычнее переставлять по сюжету и переименовывать)
- индекс убогий (просто п..ц)
Сообщение maxovt » Чт янв 12, 2006 11:41 pm
2Terrogen
Поставил ACDSee и проделал тоже: <a href='http://img11.imageshack.us/img11/4921/clipboardacds6qz.jpg' target='_blank'>ACDSee 8 Pro</a>
Кажется, что ACDSee чуть лучше IrfanView, а уж после идут PictView и, наконец, XnView.<!--QuoteBegin--><div class='quotetop'>QUOTE</div><div class='quotemain'><!--QuoteEBegin-->Вопрос в том, нужно ли это обычному юзеру, скачавшему воллпейперс с сети<!--QuoteEnd--></div><!--QuoteEEnd-->Вот на то она и Pro. 8-ка впечатление хорошое оставила (по сравнение и 4-кой, а выше версии и не смотрел уже). Очень мощный инструмент по управлению графикой со множеством фич. Только у меня не востребовано это все. Полностью устраиает связка Servant Salamander + IrfanView по управлению файлами и просмотру.
Сообщение Spike » Пт янв 13, 2006 1:13 am
ACDSee 8ка очень неплоха, Терроген уже про профиль говорил.
Очень быстра, шустрей Ирфана и ИксЭн, по крайней мере на моем компе. Наш выбор!
RUSnet #foobar2000 #miranda.
Spike
Сообщение sm@rt » Пт янв 13, 2006 8:56 am
Жаль что весит столько <!--emo&:(-->[img]style_emoticons/<#EMO_DIR#>/sad.gif[/img]<!--endemo-->
<span style='font-size:8pt;line-height:100%'>Только русские обьем называют весом и измеряют в метрах <!--emo&:)-->[img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]<!--endemo-->)</span>
Последний раз редактировалось sm@rt Пт янв 13, 2006 8:57 am, всего редактировалось 1 раз.
Вернуться в Новости софта
