Наиболее интересным в этой версии показалось просмотр thumbnails сразу во всех поддиректориях, и то, что PS и PDF теперь тоже можно просматривать (хотя Foxit Reader все же шустрей будет и функциональней, да и Ghostscript должен быть установлен в системе).
Да и еще! Кнопочка eBay исчезла. <!--emo&:)-->[img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]<!--endemo-->
<a href='http://www.irfanview.com/main_download_engl.htm' target='_blank'>Страница загрузки</a> // <a href='http://www.irfanview.com/plugins.htm' target='_blank'>Страница с плагинами</a> // <a href='http://www.irfanview.com/languages.htm' target='_blank'>Языковые модули</a> (русского пока нет)<!--QuoteBegin--><div class='quotetop'>QUOTE</div><div class='quotemain'><!--QuoteEBegin-->Version 3.98 (Release date: 2005-12-24)
- Option to support IrfanView by installing Google Toolbar and/or Google Desktop Search (OPTIONAL !)
- New Thumbnail window option: Load thumbs from all subfolders (CTRL+F)
- Alpha blending effect added for slideshow/fullscreen (Properties->Fullscreen)
- New options for fullscreen/slideshow: Set text position/alignment
- PlugIn for AFPL Ghostscript: PS, EPS, PDF formats (see Properties->PlugIns)
- Support for CGM/SVG formats : CADImage.DLL (Shareware, see i_plugins.txt)
- Support for HDR format (Formats PlugIn, thanks Kevin)
- New option for DigiCam RAW formats: Load half size image (Properties->PlugIns)
- New effects added: Sepia, Raindrops, Fragment etc. (Thanks to GENiEBEN
- Option to set the start corner for crop and text-layout in batch mode
- New placeholders for Date/Time: %Y, %m, %d (see help file for examples)
- New placeholders: $M (multipage index), $d (directory name)
- Most of normal placeholders can be used for "/convert=" too
- Option to hide main window in Thumbnails mode (Properties->Misc 1)
- New lossless JPG dialog option: Set DPI value
- Set loading options for Ghostscript, MrSID, JPM: Properties->PlugIns
- New JPG save option: Reset EXIF orientation tag
- New advanced slideshow dialog option: Play in window mode
- Command line option for EXE Slideshow: /monitor=X (start on monitor X)
- Command line option: /dpi works now for /scan, /scanhidden and /batchscan
- New special INI options to hide caption/menu bar permanently (see FAQs)
- Support for 3GP format (Quicktime PlugIn)
- New hotkeys: Red eye, Fullscreen text, Direct print, Lossless JPG (see help file)
- Several PlugIns are changed/updated
- Some minor bugs/features fixed/added (slideshow, print)<!--QuoteEnd--></div><!--QuoteEEnd-->
