Вышла новая версия этой супер утилиты
<!--QuoteBegin-"brucexs"+--><div class='quotetop'>QUOTE("brucexs")</div><div class='quotemain'><!--QuoteEBegin-->I've released rc2 as the official version 4.3.
<a href='http://www.ppro.org' target='_blank'>http://www.ppro.org</a>
I don't plan any work on PowerPro over the summer, but may due a new
release next fall.<!--QuoteEnd--></div><!--QuoteEEnd-->
<a href='http://powerpro.webeddie.com/xdownload.shtml' target='_blank'>Страница загрузки</a>
<span style='font-size:8pt;line-height:100%'><!--QuoteBegin--><div class='quotetop'>QUOTE</div><div class='quotemain'><!--QuoteEBegin-->Version 4.3 (May 2005)
new features
o Tray icon support now stable in Win XP and extended via TrayIcon command
o Use GUI Control to specify right+wheel shows alt-tab and right-drag moves/sizes windows
o Subbar display can be controlled by the active window.
o You can use a single Format ContextIf at the start of a bar to control the bar's visibility
o You can limit active buttons to 1 per exe
o Added note.search
o Added window menux option and ability to limit window menu with caption lists
o Note recycle dates now accept forms like 3 days 5 hours 10 minutes
o You can directly type hot keys when configuring them.
o added lastnotehandle, first argument gives default inputcolor(def), xcursor, ycursor, lastbuttontype
o Standard active bars ordering now like task bar on Command List|Setup|All Bars.
o *Menu ToCursor show menu as text cursor, if present
o *Bar ToCursor moves bar temporarily to text cursor, if present
o Menus now support icon sizes 48x48, 64x64, 96x96, 128x128, 256x256
o PowerPro can now read icons ;larger than 32x32 from icl files
o You can use /*…*/ for block comments in script files
o Added cl.getlastbar<!--QuoteEnd--></div><!--QuoteEEnd--></span>
</a>| <!--coloro:#009900--><span style="color:#009900"><!--/coloro--><a href="http://irc.run.net/Pix/ircmap.txt" target="_blank">RUSNet:</a> #miranda #foobar2000 #mozilla<!--colorc--></span><!--/colorc-->
