Exact Audio Copy 0.95 beta 1
Сообщение maxovt » Чт май 19, 2005 1:18 pm
Спустя 14 месяцев обновился лучший граббер Audio CD. Комментарии от автора:<!--QuoteBegin--><div class='quotetop'>QUOTE</div><div class='quotemain'><!--QuoteEBegin-->It took quite some time until this new version but I had to write my diploma thesis inbetween...
Stability should have greatly improved and there are some nice new features and some options people have requested. As a new additional feature there is now the possibility to use CDRDAO for writing CDs from EACs layout editor (like burnatonce), hope this will improve compatibility with most writers. Again, read more in the "News.rtf" file.
There is an archive with only EAC and a second one that also includes the CDRDAO package for easy download. In a few days, if everything works out, there will be also an windows installer package to make installation as easy as possible for beginners. <!--QuoteEnd--></div><!--QuoteEEnd-->Что нового в версии 0.95 beta 1?<!--QuoteBegin--><div class='quotetop'>QUOTE</div><div class='quotemain'><!--QuoteEBegin-->- Wave editor and native interface stability improved.
- Many bug fixes (E.g. extraction engine crashes, CDDB problems, compression queue).
- Added interface for CDRDAO for CD writing.
- Inserting all tracknames from Clipboard using Ctrl+Shift+V.<!--QuoteEnd--></div><!--QuoteEEnd-->
<a href='http://www.exactaudiocopy.org/eac095b1.zip' target='_blank'>Download Exact Audio Copy 0.95 beta 1 (without CDRDAO package)</a> (1,66 MB).
<a href='http://www.exactaudiocopy.org/eac095b1dao.zip' target='_blank'>Download Exact Audio Copy 0.95 beta 1 (with CDRDAO - not recommended)</a> (2,53 MB).
Сообщение Nordmoon » Пт май 20, 2005 10:28 am
<!--QuoteBegin-maxovt+May 19 2005, 14:18--><div class='quotetop'>QUOTE(maxovt @ May 19 2005, 14:18)</div><div class='quotemain'><!--QuoteEBegin-->Inserting all tracknames from Clipboard using Ctrl+Shift+V
[right][snapback]174878[/snapback][/right]
Должна быть стоящая вещь. Качаю!
Последний раз редактировалось Nordmoon Пт май 20, 2005 10:29 am, всего редактировалось 1 раз.
Nordmoon
Сообщение Terrogen » Пт май 20, 2005 11:43 am
Рулёззз! Уже диск рипнул - на точном режиме возросла скорость, ИМХО.
Всем качать!
Кстати, там есть фишка, чтобы создавать темп в ОЗУ - кто-нить пользовал, а то гиг оперативки даром пропадает. Имеет смысл такая фича?
Сообщение Ajax » Пт май 20, 2005 12:12 pm
2Terrogen
Нинаю, ты мне лучше скажи, чем рипаешь - DVDRW или нет?
Сообщение Terrogen » Пт май 20, 2005 12:15 pm
Сегодня ещё CD-RW, но уже несут 1673 - через час будет <!--emo&:)-->[img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]<!--endemo-->))
Сообщение Ajax » Сб май 21, 2005 4:19 am
2Terrogen
Так вот расскажешь... Мой 1633 упрямо желает грабить их на 3.7х-3.8х...
Сообщение Sandy81 » Пн май 30, 2005 10:11 am
Люди помогите разобраться с проблемой: Раньше была ситема XP Pro SP2ru всё работало, сделал вынужденый апгрейд железа, сейчас стоит таже система, ну может только заплаток на ОС побольше. И вот после этого перестала прога видеть мои сидюки в упор.(Teac W552E) а вот виртуальник от Demon Tools видит, причем на другой машине с такой же ситемой та же проблема, а вот на XP SP1a eng всё в норме. ASPI стоит. Как это вылечить. Версия EAC 0.95 pb5, 0.95 b1 тоже не работает.
Sandy81
Сообщение Terrogen » Пн май 30, 2005 5:36 pm
2Ajax
Рассказываю - тоже самое! <!--emo&:)-->[img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]<!--endemo-->
Сообщение Ajax » Сб июн 04, 2005 12:07 pm
2Sandy81
Какое железо-то менял?
2Terrogen
Хммм... Какие настройки? Чую я, лажаюсь где-то...
Или,может, он у тебя на шлейфе первым висит? У мну стоит мастером, но висит вторым... Всякое бывает-то...
Сообщение Terrogen » Сб июн 04, 2005 6:12 pm
2Ajax
Настройки стандартные, по умолчанию
Висит первым, стоит мастером.
Сообщение Ajax » Сб июн 04, 2005 6:22 pm
2Terrogen
Лана, разберемся...
Сообщение Terrogen » Сб июн 04, 2005 10:23 pm
А пока суть да дело - <a href='http://www.predatorsoft.com/download.php?id=1973' target='_blank'>Exact Audio Copy 0.95 beta 2</a> <!--emo&:)-->[img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]<!--endemo-->
Сообщение maxovt » Сб июн 04, 2005 10:35 pm
Release notes<!--QuoteBegin--><div class='quotetop'>QUOTE</div><div class='quotemain'><!--QuoteEBegin-->As always there were some slight bugs in the first larger release, so here comes directly a new version. Hopefully this will fix most issues with the last version. CDRDAO problems will partly persists (not starting up), perhaps try a differently compiled EXE, any with version number equal or greater to 1.1.9 should work fine.
For those who still have problems with accessing freedb using EAC, please try the command line switch "-http1.1", you can, if it works for you, enter that directly into the <a href='http://www.exactaudiocopy.de/cswitch.gif' target='_blank'>properties of the desktop shortcut</a> (the screenshot shows the german properties dialog, but the changes should be clear).
Hope you will like it :)<!--QuoteEnd--></div><!--QuoteEEnd-->What’s new in version 0.95 beta 2<!--QuoteBegin--><div class='quotetop'>QUOTE</div><div class='quotemain'><!--QuoteEBegin-->- Fixed some starting up issues and “Expecting only one toc-file” problems using CDRDAO.
- Added a new experimental command line switch for those still having freedb problems.
- Some smaller fixes.<!--QuoteEnd--></div><!--QuoteEEnd-->
Сообщение Sandy81 » Пт июн 10, 2005 10:39 am
2Ajax
Менял всё : мать(Asus P4C800 E-Delux), проц, видео, память....короче новый системник
У меня подозрения на какую то из заплаток на винду
Sandy81
Сообщение Terrogen » Чт сен 01, 2005 5:28 pm
Чего я не так делаю в субже? Внешний упаковщик - lame.exe, режим - достоверный, качество - 320кб\с. На выходе имею файлы с разным битрейдом, причём фубар грит, что типа 172кбит\сек, в эксплорере поп-уп меряет 192кбит\сек. А стояло то 320 при рипе...
Вернуться в Новости софта
