Nero Burning Rom 6.3.1.20
Сообщение Roger » Сб авг 14, 2004 6:30 pm
Изменения:
- Added support for new recorders
Nero Express:
- The user will now be informed if the DirectX version needs to be updated for handling MPEG-2 files.
Nero StartSmart:
- Support for updated help files has been added
Bug Fixes
Nero Burning Rom / Nero Express:
- A Windows XP SP2 compatibility problem is solved
- In the expert features of the preferences a localisation problem is solved
- Wrong message was shown when an installation was cancelled
- New function was added for changing the booktype with several drives
- Implemented a workaround for some device specific problems
- A problem with the audio plugin manager is solved
- Improvement for DVD+VR support on DVD+R9 media was made to determine if a layer breakpoint is set
- While opening the setting tab in the expert feature an error occurred
- Burning a VCD from a MPEG-1 file failed under Windows 95b
Nero Burning Rom:
- All controls are now disabled after the burn process is finished
- When adding data to a DVD-RW instead of overwriting existing data another media was demanded
- A problem with burning VCD is resolved
- Fixed a problem that some burnt CD medias were not readable anymore
- An unnecessary system reboot at the end of a DVD–VR disc copy process is solved
- Audio CD image copy with checked option “copy all subchannel data” resulted in a CD with silence and clicks
- Fixed a instability problem when copying a DVD-VR disc
Nero Express:
- A problem with a strange title name in Nero Express is solved
- When an AAC and a WMA file were added, the slider could not be moved
- An error occurred when trying to burn a S-VCD from a S-VCD compliant MPEG-2 file under Windows ME™
- A problem with adding DRM protected audio files to Nero Express has been solved
- The volume label name of a DVD video compilation is now corrected in case of specific system language
- A localization problem under Korean systems in the time track for creating audio CDs is solved
- The time-slider in the preview window was jumping back after moving
- Fixed a problem in the preview movie player
- A multisession CD could not be continued after two sessions
- Can’t enter more than only one Korean word in VCD disc name is resolved
- A problem with VCD burning under Windows 98 SE is resolved
- Improvement for displaying Thai text strings on some buttons was made
- Adding a video file to a compilation with the add button wasn’t possible
Nero StartSmart:
- Fixed a problem with user profiles
- Entering a new serial number was rejected with an error
- Resolved a GUI problem when switching languages
Nero BackItUp:
- Some GUI improvements are made
Nero Wave Editor:
- Playback of a WMA file failed when a file was opened the first time
Nero Cover Designer:
- A problem that was caused by clicking on the brush tool is fixed
А забираем <a href='ftp://ftp.nero.com/nero63120.exe' target='_blank'>отсюда</a>
Мой железный друг:
Roger
Вернуться в Новости софта
