ATI & Counter-Strike Ultimate Driver
Сообщение Roger » Сб авг 14, 2004 3:27 pm
Вниманию всех КСеров играющих на видюшках от ATI. Вышел специально заточенный драйвер под вашу любимую игру и видеокарту.
Собственно, что есть:
[Release Notes]
* Based on Modified Catalyst 3.8
* Based on the "Special" CS OpenGL Driver
* Optimized and Tweaked ONLY! for Counter-Strike
* Includes "Gamma" Fix!
* Includes "Random Frame drop noticed in CS" Fix!
* Includes "high recoil noticed in CS" Fix!
* Includes "Catalyst Driver's PCI Write cause input delay" Fix!
* Best performance and quality in Counter-Strike
* Highest and Stable frame rates in Counter-Strike
[Important Notes]
* Use 32bit in Counter-Strike (16bit will result in texture corruption on few cards)
(add -32bpp in Steam -> Counter-Strike -> Properties -> Launch Options)
* X800/Mobolity/FireGL cards is NOT SUPPORTED!
* No Softmods included
* Use this driver at your own risk.
* Direct3D perform "Average" in this driver.
* for full Counter-Strike performance consider using "REGENERATION's HighFPS Config V3" from the Files Section
or another tweaked CS config
* This is not NGO Driver! this driver has been "designed" to gain the maximum performance.
and to fix known issues in Counter-Strike.
and its recommended ONLY for Professional/Dedicated Counter-Strike Players
if your not Dedicated/Professional CS Player then use the latest Omega Drivers
Забираем его
<a href='http://www.newgenerationorder.org/ATICSUD.exe' target='_blank'>отсюда.</a>
Источник: <a href='http://www.tcmagazine.info/' target='_blank'>TC Magazine</a>
Мой железный друг:
Roger
Вернуться в Новости софта
