Zoom Player beta 4.01 RC1
Сообщение maxovt » Вт июл 06, 2004 9:34 am
Версия 4.01 посвящена исправлению ошибок предыдущей версии 4.00 и никаких нововведений не содержит. Финальная версия ожидается к концу месяца...
<a href='http://downloadsx-1.planetmirror.com/pub/majorgeeks/multimedia/zp401rc1std.exe' target='_blank'>Скачать Zoom Player Standard beta 4.01 RC1</a> >> (976 kb, Freeware)
Скачать <a href='http://downloadsx-1.planetmirror.com/pub/majorgeeks/multimedia/zp401rc1pro.exe' target='_blank'>Zoom Player Professional beta 4.01 RC1</a> >> (1038 kb, Shareware)
Сообщение maxovt » Ср июл 07, 2004 5:54 am
А вот и список изменений<!--QuoteBegin--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>Цитата </td></tr><tr><td id='QUOTE'><!--QuoteEBegin-->* AC3Filter profile for Customized DVD filters.
* H264 profile for Customize Media Mode using the VideoSoft decoders.
  <a href='http://www.videosoftinc.com/decoders.html' target='_blank'>http://www.videosoftinc.com/decoders.html</a>
* Skin files can now be grouped within directories under the Skins dir.
+ Workaround for certain versions of the NVIDIA ForceWare (NVDVD) v3.xx
  filters not working with Zoom Player.
+ When the main window is minimized, opening a new file through an
  external program (such as explorer) won't make the window reappear.
+ MPEG2 Transport has been given its own path in customized media mode so
  that you can pick a different video decoder for standard MPEG2 and for
  MPEG2 Transport.  Since the formats are essentially the same, the
  distinction is done by the file extensions of the playing files
  (TS/TP/TSP considered MPEG2 Transport, every other extension is assumed
  to be standard MPEG2).
+ The Red Error dialog now resizes to fit the content of
  the error message.
+ Switched to a different EXE compressor.
- Filter Blacklisting was broken in Zoom Player Standard.
- When not logged in with administrator privlages, a user should still
  be able to see which decoders are missing on the system and which
  decoders are currently installed for the various formats.
- Color Controls were not working in DVD VMR9 Windowed mode.
- Aspect Ratio with certain WMV files (T2:UE, Taxi3) should now work
  correctly as long as you use VMR9 as the video renderer and disable
  the "Fix VMR9 Scaling Bug" setting (Advanced Options / Filter Control).
- The "Auto-Get Duration for Media Extension" value didn't save properly
  under some conditions.
- When using Inverse Scene Cut, the current file would play in a loop
  between the cut segments instead of moving to the next track.
- The filter versions shown on the Formats / System dialog were for
  the wrong files.
- Fixed a few cosmetic glitches with the Windows XP theme.<!--QuoteEnd--></td></tr></table><div class='postcolor'><!--QuoteEEnd-->
Вернуться в Новости софта
