Сейчас проходит тестирование новой версии программы Talisman Desktop, оболочки Windows заменяющей стандартную Windows Exporer.
На текущий момент доступна <a href='http://www.neosoft.ru/files/t2b.zip' target='_blank'>Talisman Desktop 2.8 beta (build 2803)</a> (4900 kb).
История изменений<!--QuoteBegin--><div class='quotetop'>QUOTE</div><div class='quotemain'><!--QuoteEBegin-->New in build 2802
- Corrected startup procedure
- Fixed small bugs
New in build 2802
- Fixed "Insert disk in drive A" startup bug
- Fixed VB-applications minimizing bug
- Fixed "tobject <form>.<list>.listpath=recentfiles" command bug
- Fixed [event] command for TextBlock in OnTop forms bug
New in build 2801
1. Using ontop forms as Main Menu. Just enter "showtopform <your form>" command in the Main Menu command box. You can use also any Talisman command instead right click Main Menu.
2. New options for Calendar object: displaying events and texts in the associated Text Block. Events texts are stored in the new ../talisman/events/ subdirectory.
3. Added "TimeZone" option for the Sytem Clock object.
4. Added scripts function for the Sytem Clock object. Sytem Clock can execute user-defined scripts under a time-table. This new option allows to create reminders and other time-depended functions in Talisman.
5. New plugin sendcommand.exe. Use "sendcommand.exe" to send any Talisman command string from your own applications or Flash movies into Talisman. Syntax:
sendcommand.exe <command string>
Note: sendcommand.exe must be placed in your application/Flash folder to be available from your application/Flash movie.
6. Updated Lvolume plugin. Added Title indicator and Track Position controls for Winamp mediaplayer.
7. Updated LDrive plugin. Added drive menu, displaying of removable and network drives, horizontal orientation option for drive panels.
8. Updated LZoom plugin. Added RGB indicator and other options.
9. New options for Inputbox object: using a text entered in the InputBox as a parameter for compound commands; replacing symbols in the entered string. These new features allow to create Google Search box and other similar functions.
10. Added Connect menu (connectmenu <parameters>), Connect submenu (submenu connections) and Connections parameter for the List object.
11. Added Drives menu (drivesmenu <parameters>), Drives submenu (submenu drives).
12. Added Recent Files menu (recentfilesmenu <parameters>), Recent Files submenu (submenu recentfiles) and Recent Files parameter for the List object. Added [type:*] parameter for Recent Files functions (allows to create menus or lists of recent files for selected apps).
13. Added Recent Folders menu (recentfoldersmenu <parameters>), Recent Folders submenu (submenu recentfolders) and Recent Folders parameter for the List object. (These functions work only on WindowsXP computers.)
14. New effects for wallpapers: Flip Horizontal, Flip Vertical, Mirror Left, Mirror Right, Mirror Top, Mirror Bottom.
15. New effects for the Picture object: Flip Horizontal, Flip Vertical, Mirror Left, Mirror Right, Mirror Top, Mirror Bottom.
16. Added "Tasklist" parameter for the List object.
17. Added "Themes" parameter for the List object.
18. Added "themesmenu" command.
19. Added "newmenu" command.
20. Talisman tray icon, Connection icon and Language icon are optional and may be hidden.
21. Added popup menu for drives in the List object.
22. Fixed "Minimization" bug in Talisman Taskbar for some applications.
23. Fixed bug of Analog Clock objects in OnTop forms.
24. Fixed bug of "tobject mediaplayer" command used from OnTop forms.
25. Fixed special symbols bug (& , ' " and etc) in filenames.
26. Other changes.<!--QuoteEnd--></div><!--QuoteEEnd-->
