Делаю все по хелпу
<!--QuoteBegin--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE </td></tr><tr><td id='QUOTE'><!--QuoteEBegin-->Combine files
This function allows to combine multiple files to one big file. Total Commander can not only combine files created with its own function split file, but also files created with the Unix command split -b. Put the cursor on the first partial file and choose 'combine files'. The file names must be numbered in ascending order, or have letters in ascending order. Total Commander will detect file.001, file.002, file.003, but also fileaa, fileab, fileac etc.
If a file with the same name and the extension .crc is found in the same directory as one of the partial files, Total Commander will use this file to check the combined file for errors. Furthermore the original file name stored in the CRC file will be used as the target name for the combined file.
Combine XXX and all files with ascending names to the following directory:
Here you can enter the target path. Leave this field empty to combine the files in the current. directory.<!--QuoteEnd--></td></tr></table><span class='postcolor'><!--QuoteEEnd-->
Но ТС выдает "Вставте следующий диск или укажите другой каталог". Что за дела не пойму?! <!--emo&:blink:-->
