Новости о Foobar2000
Волшебное слово "Скачать"!
Сообщение pvmail » Вс окт 21, 2007 6:33 pm
14.10.2007 выпущена финальная версия
foobar2000 0.9.4.5
<a href="http://www.foobar2000.org/foobar2000_0.9.4.5.exe" target="_blank">http://www.foobar2000.org/foobar2000_0.9.4.5.exe</a>
*Musepack SV8 decoding support
21.10.2007 вышка перспективная и очень интересная бэтка
foobar2000 0.9.5b
новости о бэтке
<a href="http://www.foobar2000.org/beta/index.html" target="_blank">http://www.foobar2000.org/beta/index.html</a>
New Default User Interface
Allows embedding of Album List and other components in the main window
Quick setup dialog on first startup allowing easy UI customization
Theme import/export support for transferring appearance-related settings easily
Built-in playlist view supports columns and grouping
New Playlist Search dialog
Embedded album art support
New built-in spectrum visualisation
New Album List component
Updates automatically with Media Library content changes (”Refresh” command no longer needed)
Embeddable in the main window
Supports direct creation of autoplaylists from Album List tree branches
Properties dialog improvements
New commands: ”Format from Other Fields”, ”Capitalize”, ”Clean Up”
Improved ”Automatically Fill Values” functionality
Improved Windows Clipboard interaction - now you can use copy/paste to transfer values between fields or between different sets of tracks
Converter component improvements
Replaced ”show output directory when done” functionality with a new dialog showing a list of created tracks
Built-in support for writing AU/SND and AIFF files
Updated FLAC support - FLAC encoding now requires FLAC encoder 1.2.0 or newer
Improved handling of hung command-line encoder processes
Audio format decoding updates
Updated libFLAC to 1.2.0
Rewritten support for AU/SND and AIFF audio formats
New ”File Operations” component, for moving, copying and deleting audio files
Old Masstagger component no longer included with the installer (available for download separately)
Windows XP or newer is now required
скачать
<a href="http://www.foobar2000.org/beta/foobar2000_0.9.5" target="_blank">http://www.foobar2000.org/beta/foobar2000_0.9.5</a> beta 1.exe
Последний раз редактировалось pvmail Вс окт 21, 2007 6:35 pm, всего редактировалось 1 раз.
pvmail
Сообщение panda » Вс окт 21, 2007 10:19 pm
хм, интересно. а ссылку поправь.
Сообщение eDio » Ср окт 24, 2007 11:04 am
Новый интерфейс не понравился, мало свободы. Но визуальное редактирование - это круто! Еще не понравилось, что в новом интерфейсе все элементы свои, т.е. свой родной AlbumList, родной Infobox и т.д. Но это всё круто, а вот настроить эти элементы нельзя - и это плохо.
Остаюсь верен ColumnsUI
eDio
Вернуться в Файлы Foobar2000
