Обновилась UltraISO до версии 5.5:
UltraISO is a CD image editing tool, it can directly edit the CD
image file and extract the document from it, also can directly
build ISO file from CD-ROM or hard disk. At the same time, you
also may process the ISO bootable information, thus create your
bootable CD. Uses UltraISO, you can have one's wish to
make/edit the ISO file, and then burn the CD oneself needs.
UltraISO runs on Win95/98/Me/NT/2000/XP operating system.
UltraISO can do:
1. Duplicate disc to ISO file from CD-ROM.
2. Build file on hard disk, CD-ROM, net drive to one ISO file.
3. Extract files from ISO file.
4. Edit ISO file in many format(such as Nero burning ROM,
Easy CD Creator, CDRWin, CloneCD, BlindWrite, etc.).
5. Make bootable ISO file.
Some details:
1.Directly edit the ISO image file.
2.Directly extract files and folder form ISO image file
3.Support willfully add / delete /create new directory /rename
ISO file content.
4.Make ISO file form hard disk document.
5.Create CD image from CD-ROM, maintain bootable information.
6.Handle the compact disc boot information, you may directly
add/remove/extract boot image of the ISO document.
7.Support nearly all known CD image file format(ISO,BIN,IMG,
CIF,NRG,BWI and so on), and converts them to the standard
ISO form document.
8.Directly set the file/folder to hidden attribute
9.Supports ISO 9660 Level1/2/3 and Joliet extension
10.Automatically optimizes the ISO document file structure,
saves the CD space.
11.Supports the shell document type integration, may through
double click or the mouse right key menu in the Windows
resource management to open the ISO file.
12.Twin window operation, it is extremely convenient to use.
13.There are rich add-on tools, you may create N in 1 bootable
compact disc, CD image file management, even the virtual
CD/DVD drive , those function is really powerful.
UltraISO revision history
December 10th, 2002 UltraISO 5.5 released
+) Fully bootable CD specification support
+) Support more than 19 CD Image format, include:
BlinkWrite *.BWI/*.BWT
CDSpace *.LCD
CDRWin *.BIN/*.CUE
CloneCD *.IMG/*.CCD
Easy CD Creator *.CIF
Fantom CD *.MDF/*.MDS
Farstone Virtual Drive*.VCD
Nero - Burning ROM *.NRG
Noum Vapor CDROM *.VaporCD
Paragon CD Emulator *.CDI
VCDROM Extension *.FCD
Virtual CD *.VC4/*.000
Virtuo CD Manager *.VDI
Other *.TAO/*.DAO
+) Support long filename up to 110 characters
+) Directly extract boot file form CD
+) Realizes make floppy image function
+) Realizes CD image convert function
+) Realizes "Extract To" popup menu
*) Fixed SUPER RESTORE file time recovery problem
*) Some minor bugs fixed
Home page download:
<a href='http://www.ultraiso.com/2324487/uiso55en-a.exe' target='_blank'>http://www.ultraiso.com/2324487/uiso55en-a.exe</a>
Лекарство подходит от версии 5.1 TMG.NFO(искать на форуме kpnemo.ru в разделе Warez)
От себя: версия 5.1 в сравнении с WinISO выглядела послабее...
