Гологрпфические мониторы
Сообщение -=NV=- » Чт авг 18, 2005 8:29 pm
<a href='http://www.io2technology.com/dojo/204/v.jsp?p=/technology/overview' target='_blank'>сайт первоисточник</a>
взято с nnm.ru
<!--QuoteBegin--><div class='quotetop'>QUOTE</div><div class='quotemain'><!--QuoteEBegin-->The Heliodisplay includes patented and patent pending technology to transform normalambient air and display video images into free-space. Some Heliodisplay models are interactive allowing a finger or hand to move images around in the air as if one were grabbing a tangible object.
The Heliodisplay requires a power outlet, and a computer, TV, DVD or alternate video source. The current version of the Heliodisplay projects a 22" to 42" (depending on model) diagonal image that floats above the device. The Heliodisplay system is backward compatible and accepts most 2D video sources (PC,TV, DVD, HDTV, Video game consoles). For connection to a computer, the Heliodisplay uses a standard monitor VGA connection; for TV or DVD viewing, it connects using a standard RGB video cable.
Heliodisplay images are easily viewed in an office environment. Like any computer monitor or TV, images appear brighter the lower the ambient light. Also, just like viewing any computer monitor or TV, viewing a Heliodisplay image in direct sunlight is almost impossible.
The Heliodisplay is interactive, like a virtual touchscreen. A hand or finger can act as a mouse. No special glove or pointing device is required. Just as you use a mouse to move the cursor on a traditional computer monitor, you can use your finger to move the cursor around the Heliodisplay image (see: Images & Videos).The Heliodisplay connects to a computer (at least: Pentium III 400MHZ;25MB free disk space;Win2000/XP) through a USB port.
Operating the device will not change a room's environment, air quality or other conditions. Air comes into the device, is modified then ejected and illuminated to produce the image. Nothing is added to the air so there isn't any harmful gas or liquid emitted from the device. If a Heliodisplay were left running for a week in a hermetically sealed room, the only change to the room`s environment would be from the electricity used to run the device. Although the Heliodisplay uses lasers, the images are not holographic.
Heliodisplay включает в себя патентованные и ожидающие выдачи патентов технологии, используемые чтобы трансформировать обычный воздух и показывать видео изображение в пространстве. Некоторые модели Heliodisplay - интерактивны и позволяют пальцем или рукой передвигать изображения в воздухе, как бы перетаскивая их.
Для работы Heliodisplay неообходим источник питания и ПК, ТВ, или другой источник видеосигнала. Существующие версии устройства проецируют изображение (с диагональю от 22 до 42 дюймов), которое находится в воздухе над устройством.Эта система обратно совместима с большинством обычных плоских устройств (ПК, ТВ, DVD, HDTV, приставки). Для подсоединения пк используется обычный разъём VGA, для всего остального - стандартный RGB-кабель.
Изображение Heliodisplay будет хорошо видно и в обычном офисе. Как и у любого монитора или телевизора изображение будет ярче, если в помещение будет затемнено. И таким же образом изображение почти невозможно рассмотреть в прямом солнечном свете.
Heliodisplay имеет обратную связь, как виртуальный тачскрин. Рука или палец могут действовать как мышь. Никаких перчаток или других устройств не потребуется. Подсоединяется этот интерфейс к компу через USB.
Работа устройства не изменяет окружающее пространство, структуру воздуха или другие внешние условия. Воздух, попадающий в устройство модифицируется, затем выбрасывается и подсвечивается, чтобы создать изображение. К воздуху ничего не добавляется, поэтому устройство не является источником каких-либо вредных газов и жидкостей. Если оставить Heliodisplay работать в герметичном помещении на неделю, то единственное, что повлияет за это время на воздух будет электричество (они подразумевают ионизацию?). Хотя Heliodisplay использует лазеры изображение не является голограммой (И к чему бы это в абзаце про безопазность?).
Отображаемое мзображение имеет 2 измерения (то есть оно плоское). Однако изображения кажутся трёхмерными, когда на них смотрят более чем с двух метров, потому что отсутствует физическая зацепка для глаз. Общий угол обзора составляет 150 градусов - близко к ЖК-экранам. Просмотр не требует очков или каких-либо экранов.
___
Это всё. Плюс в какой-то новостной ленте проскальзывала цена от 18 500 долларов<!--QuoteEnd--></div><!--QuoteEEnd-->
-=NV=-
Сообщение sm@rt » Пн авг 22, 2005 7:53 am
Здорово. Только качество похоже пока страдает.
