Opera 9.0
Сообщение Elzor » Сб окт 22, 2005 6:48 pm
<a href='http://snapshot.opera.com/windows/o90p1_8031.exe' target='_blank'>Скачать (Windows)</a>
<a href='http://snapshot.opera.com/unix/9.0-Preview-1/' target='_blank'>Скачать (*nix)</a>
<!--QuoteBegin--><div class='quotetop'>QUOTE</div><div class='quotemain'><!--QuoteEBegin-->Changes Since Opera 8.5
User Interface
Enhanced pop-up blocker to detect more unwanted pop-ups.
Added new message console for warnings and error messages.
Added opera:config for managing preferences.
'Find' feature now highlights all matches when searching for text on the page.
Added internal source viewer. Set 'Source viewer' preference to 'Opera' to use the internal source viewer. On new installs, the internal source viewer is enabled by default.
Implemented tab locking. Right click on a tab and select 'Lock tab'. Individual tabs cannot be closed while they are locked.
New bookmark icon in address bar.
Fix to prevent key presses being lost after using Alt+Tab.
Updated search.ini
The file version number is now 7. All files with lower version numbers will be overwritten on upgrade.
New shortcut 'a' for searching with answers.com.
Changed keyboard shortcuts for closer cross-browser compatibility:
Ctrl+T replaces Ctrl+N for opening a new tab.
Ctrl+N opens a new browser window.
Ctrl+D and Ctrl+Shift+D replace Ctrl+T and Ctrl+Shift+T, respectively, for adding pages to bookmarks.
Ctrl+Shift+V can be used instead of Ctrl+D for paste-and-go.
Messaging and Newsfeeds
Enabled new IMAP code.
New account storage format. If you install over an existing profile, you will be prompted to convert all accounts into the new format. This will not require a re-index.
Added support for Atom 1.0.
External embeds are now always allowed in newsfeeds, and are not disabled when the "Surpress external embeds" preference is set.
Fix to prevent chat windows going blank when redrawing from cache.
Security
TLS 1.1 and TLS Extensions enabled by default.
SSL v2 and weak encryption methods (56 bit and lower) are disabled by default. See our knowledgebase for more information.
Upgraded crypto library to OpenSSL 0.9.8.
Please report problems accessing secure sites that worked in previous versions of Opera.
HTML
Added support for Web Forms 2.0.
Implemented support for canvas.
Improved handling of the align attribute.
Removed support for XML namespaces in HTML documents.
Allowed negative numbers in numbered lists.
Added support for xml:id.
Added option to re-parse invalid XML documents as HTML after XML parsing has failed.
Fix to prevent minimized boolean attributes from being ignored if they are followed immediately by a / character.
HTTP
Changed default UserAgent string to identify as Opera.
Fixes to prevent delays when using proxy servers.
Added support for the HTTP Link header.
Scripting
Added support for XSLT 1.0 and the XSLTProcessor constructor.
Added support for XPath 1.0.
Implemented designMode for rich text editing.
Implemented Node.textContent property from DOM 3 Core.
Added support for onreadystatechange events, and the readyState property.
Implemented scripting support for canvas.
Added window.getSelection, and associated methods.
XMLHttpRequest returns the status code for the cached page if the request returns the cached page.
Fix to allow scripts to override a CSS #double #id selector.
Fix to prevent CSS generated content being duplicated when element contents are changed with scripts.
Fix to reset scrolling as needed when removing content from an element with overflow.
Plug-ins
Added Netscape Plug-in API extensions developed by browser and plug-in vendors.
Fixed an issue when printing from Java.
Display
Acid2 fixes
Several fixes for margin collapsing model.
Prevented elements from being less than 0 pixels high.
Create an anonymous table cell around tables inside an anonymous table row.
Table backgrounds are rendered if the table has dimensions, but no contents.
:before rules in CSS do not cause unrelated form elements to disappear.
Margins correctly treated on elements with clear: that follow a float.
Comments in strict HTML documents are treated as SGML comments.
Intersection of borders compatible with reference rendering.
Corrected use of :hover with no element selector.
Overflow on the HTML element is applied to the viewport.
Elements with overflow:hidden; can scroll to anchors within them.
Defaults
Body element now uses margin instead of padding by default.
UL/OL elements now use padding instead of margin by default.
DD elements now have a smaller indent.
Use default handheld font size for handheld stylesheets.
Images
SVG support increased to partial SVG 1.1 basic.
Selectors
Added support for CSS 3 attribute and UI selectors.
Fix to allow combinations of + or *, with :active, :focus, and :hover selectors.
Fix for combined :hover::after.
Multiple :first-line fixes.
:lang() selector no longer applies to xml:lang attributes.
Improved error handling for nested {}, [], and () blocks.
Selectors with invalid css identifiers are ignored.
Improved handling of unicode escape characters in ID selectors.
Backslash escapes allowed in ID selectors.
Correctly treat semicolons in @-rules.
Support media queries in @import rules.
Box, table, and inline
Removed box model quirk (box-sizing:border-box;) in quirks mode.
Fixed display:inline; on table rows.
Fixed percentage widths on button elements.
Fixed default padding and border spacing on elements with display:table-cell;
Fix to allow padding in TD and TH elements to detect mouse events and :hover.
Fix for margin-top being mis-interpreted as padding-top.
Positioning
Allowed positioned elements to appear in front of iframes and objects.
Position and dimensions of absolutely positioned and fixed position elements are treated correctly when they are nested inside each other.
Fix to allow float, position, and z-index to be combined.
Absolutely positioned elements now take percentage widths relative to their parent container.
Lists and generated content
Respect list-style even if 'none' is specified for list-style-image.
List-style-image is now respected on :hover.
content:attr() now works for 'style' attributes.
Fixed margins of generated content for inline elements.
Background
Prevented background color of pseudo elements propagating to parent element.
Prevented background of html::before overriding background of html.
Object iframes now accept transparent backgrounds.
Other display
Fix to prevent fixed positioned elements from remaining visible when hiding them with display: none;
Fix to prevent positioned content, hidden using overflow, from producing a scrollbar.
Added support for quotes:none;
Multiple bidi, decoration, forms and paged media fixes.
Improved display of frames when 'Fit to window width' is enabled.
Miscellaneous
Site-specific settings are now available as part of the site-specific ini settings. A User Interface for these settings is not yet available.
Multiple stability fixes.
Windows specific fixes
Fonts selection now works correctly when more than 1024 fonts are installed.<!--QuoteEnd--></div><!--QuoteEEnd-->
Последний раз редактировалось Elzor Вс окт 23, 2005 9:12 am, всего редактировалось 1 раз.
Elzor
Сообщение Terrogen » Вс окт 23, 2005 3:43 pm
Ставил кто-нибудь, ау?
<!--QuoteBegin--><div class='quotetop'>QUOTE</div><div class='quotemain'><!--QuoteEBegin-->Про 9 версию по русски:
Интерфейс программы:
+Блокиратор всплывающих окон теперь перехватывает больше нежелательных страниц.
+Добавлена консоль для отображения предупреждений и сообщений об ошибках.
+Добавлена возможность управления расширенными настройками через команду "opera:config".
+Поиск теперь подсвечивает все найденные элементы на странице.
+Добавлен встроенный редактор для просмотра исходного кода страниц.
+Добавлена блокировка страниц - нажатием правой кнопки на заголовке страницы и выбором "Lock Tab". Одиночные страницы при блокировке не могут быть закрыты.
+Добавлена новая иконка закладок в адресной строке.
+Устранено несрабатывание клавиатурных команд после использования Alt+Tab.
+Обновлен конфигурационный файл search.ini: используется новый внутренний номер версии файлов (седьмой), все файлы с более низким номером версии будут заменены новыми при инсталляции; добавлено сокращение "a" для поиска через answers.com.
+Изменены комбинации клавиш для большей совместимости с другими браузерами: Ctrl+T вместо Ctrl+N при открытии новой страницы; Ctrl+N для открытия нового окна браузера; Ctrl+D и Ctrl+Shift+D вместо Ctrl+T и Ctrl+Shift+T для сохранения закладок; Ctrl+Shift+V в дополнение к Ctrl+D для вставки адреса с одновременным его открытием.
Почта и новостные ленты:
+Переработан код управления IMAP.
+Использован новый формат при хранении писем.
+Добавлена поддержка лент Atom 1.0.
+Внешние вложения в новостных лентах теперь разрешены всегда.
+Исправлена ошибка с отображением пустого окна чата при открытии его из кэша.
Безопасность:
+TLS 1.1 и расширения TLS включены по умолчанию.
+SSL 2 и ненадежные методы шифрования (56 bit и ниже) отключены по умолчанию.
+Библиотека OpenSSL обновлена до версии 0.9.8.
HTML:
+Добавлена поддержка WebForms 2.
+Реализована поддержка полотен.
+Улучшена обработка атрибута "align".
+Добавлена поддержка xml:id.
+Добавлена возможность повторного просмотра ошибочных XML-документов как HTML.
+Внесены некоторые другие изменения.
HTTP:
+Идентификатор браузера (поле "UserAgent") по умолчанию сменен на Opera.
+Уменьшены задержки при использовании прокси-серверов.
+Добавлена поддержка заголовков HTTP Link.
Работа со скриптами:
+Добавлена поддержка XSLT 1.0 и XPath 1.0.
+Улучшена поддержка XMLHttpRequest.
+Исправлено несколько ошибок.
Плагины:
+Исправлена ошибка при печати Java-документов.
Отображение страниц:
+Внесено более десятка изменений для корректного отображения страниц в тесте Acid2.
+Изменено несколько используемых по умолчанию элементов.
+Добавлена частичная поддержка SVG 1.1.
+Добавлена частичная поддержка CSS 3.
+Внесено более трех десятков других изменений и исправлений.
+Настройки отдельных сайтов теперь доступны через настройку соответствующих секций ini-файла, графический интерфейс для их настройки пока недоступен.
+Внесены множественные исправления, направленные на повышение стабильности работы<!--QuoteEnd--></div><!--QuoteEEnd-->
Сообщение Ajax » Вс окт 23, 2005 4:23 pm
А вам не кажется, что это уже... смешно? <!--emo&:)-->[img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]<!--endemo-->
То есть смешно - вот так, непонятно зачем, постепенно менять номер! Надо сразу сделать 20-ю или 50-ю вресию, чтоб красиво!
Сообщение Elzor » Вс окт 23, 2005 4:23 pm
<!--QuoteBegin-Terrogen+Oct 23 2005, 21:43--><div class='quotetop'>QUOTE(Terrogen @ Oct 23 2005, 21:43)</div><div class='quotemain'><!--QuoteEBegin-->Ставил кто-нибудь, ау?
[right][snapback]189190[/snapback][/right]
<!--QuoteEnd--></div><!--QuoteEEnd-->Естественно. Поставил. Глюков не заметил. Пользую.<!--QuoteBegin--><div class='quotetop'>QUOTE</div><div class='quotemain'><!--QuoteEBegin-->А вам не кажется, что это уже... смешно?<!--QuoteEnd--></div><!--QuoteEEnd--> Нет, не кажется. Хотя бы потому, что нововведений вполне достаточно для смены номера версии. Плюс - это только TP1. Финал может кардинально отличатся по возможностям.
Последний раз редактировалось Elzor Вс окт 23, 2005 4:29 pm, всего редактировалось 1 раз.
Elzor
Сообщение DruiD » Вс окт 23, 2005 4:42 pm
2Ajax согласен. Нездоровое поветрие.
Сообщение Night Angel » Вс окт 23, 2005 5:53 pm
Ставил, ничего интересного, тест Acid2 проходит почти совсем. А так ничего особенного не увидел.
<span style='color: #999999'>Добавлено([mergetime]1130090038[/mergetime]):</span>
Кстати, я в пятницу писал, а новость не одобрили видать.
Сообщение Terrogen » Вс окт 23, 2005 6:41 pm
2Night Angel
А все писали - просто там конкурс сочинений :)))
Сообщение DruiD » Вс окт 23, 2005 7:13 pm
opera:config мне понравился.
Сообщение maxovt » Вс окт 23, 2005 7:22 pm
Какая разница какой номер? Кажется, у Оперы это нормальная тенденция такая смена.
2Ajax
Тебе этого недостаточно? <!--emo&:)-->[img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]<!--endemo-->
Сообщение Sh0Ck_filE » Пн окт 24, 2005 2:22 am
Я поставил... opera:config действительно потрясный. Больше ничего мегакрутого не нашёл, кроме номера порядкового ^_^
Сообщение SpideRus » Пн окт 24, 2005 4:05 am
Еще не успел 8.50 Final попользоваться вдоволь, а уже что-то новенькое. Конечно интерессно.
SpideRus
Сообщение st1nger » Пн окт 24, 2005 4:24 am
То есть смешно - вот так, непонятно зачем, постепенно менять номер! Надо сразу сделать 20-ю или 50-ю вресию, чтоб красиво!<!--QuoteEnd--></div><!--QuoteEEnd-->
Вы чего народ? А как же поддержка WebForms 2, XSLT, Xpath, DesignMode, SVG, Canvas, CSS3-селекторов? А чтобы браузер проходил хардкорный Acid2-тест им тоже пришлось движок переписывать и отлавливать море багов! Оперцами уже проделана огромная работа.
Кроме того Девятка обошла по скорости рендеринга восьмую оперу (см. обновленный тест браузеров <a href='http://www.howtocreate.co.uk/browserSpeed.html)' target='_blank'>http://www.howtocreate.co.uk/browserSpeed.html)</a>. А в веб-интерфейсе gmail при создании нового письма заработал Rich Text Formating.
Так что вполне адекватная смена номера версии на 9.0!
Ей бы еще морду новую, но это скорее всего будет в следующих релизах (возможно что не раньше финала). Не забываем, что сейчас на публику выложена только самая первая и самая сырая Бета не предназначенная для использования!
<!--QuoteBegin--><div class='quotetop'>QUOTE</div><div class='quotemain'><!--QuoteEBegin-->Я поставил... opera:config действительно потрясный. Больше ничего мегакрутого не нашёл, кроме номера порядкового <!--emo&^_^-->[img]style_emoticons/<#EMO_DIR#>/happy.gif[/img]<!--endemo--><!--QuoteEnd--></div><!--QuoteEEnd-->
Ага, opera:config хорош по задумке. Ему кстати можно дизайн через config.css править. На my.opera.com люди уже смастерили свои css - настроили например чтобы фон конфига был как стандартный фон текущего скина. А другой умелец уже засунул opera:config в сайдбар (в качестве боковой панельки), причем таким образом чтобы opera:config туда полностью разместился без горизонтальных полос прокруток.
А еще появилась прикольная комманда "Set preference <номер настройки>". Это позволит переключать в Опере прокси-серверы "на лету" с помощью кнопок, хоткеев, жестов. Ну и другие настройки тоже можно менять, не прибегая к окну Preferences.
Еще понравилась новая фича - "Lock tab". Давно пора было ее приделать. В остальном изменений в интерфейсе почти нет. Я надеюсь что к выходу релиза ситуация к интерфейсом исправится и появятся новые фичи.
Последний раз редактировалось st1nger Пн окт 24, 2005 4:24 am, всего редактировалось 1 раз.
st1nger
Сообщение Spike » Пн окт 24, 2005 4:36 am
/me апплодирует!
Но качать пока не буду. Только что смастерил мобильную версию 8.5 на флешку (при помощи софтины Moper1.4Plus), так что пока воздержусь. А так новость радует.
Про Оперу несколько неутвержденных тем, кстати, в новостях...
RUSnet #foobar2000 #miranda.
Spike
Сообщение st1nger » Пн окт 24, 2005 5:37 am
/me издевается над девяткой в порядке эксперимента
Вы когда-нибудь видели браузер, который умеет менять прокси сервер одним жестом мыши? Opera 9 может.
Set preference, "Proxy|HTTP server=proxy:8081"
st1nger
Сообщение Spike » Пн окт 24, 2005 6:32 am
2st1nger
Ничего, для фокса скоро плаг выпустят %), они на это дело падкие
Spike
Вернуться в Новости софта
