TheBat! v3.60 Professional edition
Сообщение Terrogen » Чт сен 01, 2005 10:47 pm
Обновилась Мышь почтовая <!--emo&:)-->[img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]<!--endemo-->
<a href='http://www.ritlabs.com/download/the_bat/thebat_pro_3-60.msi' target='_blank'>TheBat! v3.60 Professional edition</a> 9.3M
<a href='http://www.ritlabs.com/download/the_bat/intpack.msi' target='_blank'>Языковой модуль</a>4.3M
Сообщение Terrogen » Пт сен 02, 2005 10:13 pm
The Bat!
Copyright © 1997-2005 RITLABS S.R.L.
Version 3.60
What's new in The Bat! 3.60 (comparing to v3.51) ?
[ Legend: ]
[ ! Major Improvement ]
[ + Added feature ]
[ * Improved/changed feature ]
[ - Bug fixed (we hope) ]
[+] Zoom pictures in HTML viewer
[+] Search in encrypted messages
[+] Automatic hotkey assignment to menus, toolbars and popups
[+] You can now edit SmartPad preferences
[+] Complete integration of setting colour groups on IMAP
[+] Exchange: You can use existing profiles with Exchange Mail Server, just go to Account|Properties|Transport and select "Existing Profile" choice.
[-] (#0004818) Configuration file TBUSER.DEF (TBUSER.EEF in OTFE) was not backuped by internal Maintenance Centre
[-] TBUSER.DEF didn't migrate to TBUSER.EEF
[-] There was a bug in replying to HTML messages
[*] Writing user config (USERDEPT.INI) after reading this file at startup no longer performed.
[-] The position of the cursor is wrong when changing between the editors.
[-] (#0003889) Micro-Editor, selective shift/arrow button quoting from RTV, Smileys enabled, Smiley handles are not quoted.
[-] (#0004919) Context menu for attachments not properly working
[-] (#0004872) color selection dialog in table property cannot be translated
[-] (#0004729) Popup menu in Scheduler (Edit Event Window - Tab Actions) can be applied on another grid
[-] (#0004849) Window Scheduler - Edit Action - Refilter Action appears partially out of display
[-] (#0004150) After pressing "menu" key context menu shows in the left top corner of area of editing
[-] (#0004851) Two Credits Overlap
[-] (#0004959) About box glitches
[-] (#0004955) Container item can't be hided by "Hidden item" and is not auto-hided, when all sub-items are hided
[-] (#0004954) Question "You have unsaved changes. Apply them now" appears even no changes were made
[-] (#0004866) Dynamic items for Remind Later are not refreshed on language change
[-] (#0005002) VF unread count increases by 1 every time it is manually refreshed
[-] (#0003159) Menu navigator output is wrong
[-] Fixed different memory leaks
[-] IMAP : memory usage during message list request
[-] VFs: un-expected AV if auto-refresh enabled
[-] Automatic hotkey (shortcut) assigned only to chars of some alphabets only
[*] The Bat! now uses PCRE 6.2 with Unicode support for Perl-Compatible Regular Expressions
[-] When displaying certificate properties, ASN.1 Object Identifiers were incorrectly shown
[-] There were an AV when verifying PGP signatures by PGP internal implementation
[*] right alignment of name column in message header pane
[-] Bugs with MAPIReadMail, AV errors on exit when Simple MAPI was used
[-] Bug in processing SimpleMAPI requests causing slow functioning of the subsystem
[*] some cosmetic fixes for SimpleMapi
[-] (#0005005) Failure while changing folder name in OTFE
[-] Other: account couldn't be moved up/down
[-] Other: cursor Tabbing problem in Headers
[*] Added more free space around progress characters in the view of window of backup progress.
[-] (#0004781) "Check folder for viruses" did stop checking after the first error of an antivirus plugin.
[-] (#0005034) Autohotkey feature make the chinese translation wrong
[-] (#0003102) eMail received with charset=iso-2022-jp via MAPI (Exchange) or imported from Outlook have no text in the body
[-] ampersands in the toolbutton hints
[-] (#0005051) hotkeys not assigned to extended Latin chars
[-] (#0005044) White space in Header Pane with 'Sender Photo' | 'Fit Headers to Image' selected
[-] The Bat! didn't move folders across tree levels in On-The-Fly encryption mode.
[*] Infrequently-used tree items in the account properties are collapsed by default
[-] Search: stuck on signed HTML messages with attachments
[*] Updated ZLib to version 1.2.3
[*] libpng updated to v1.2.8
[-] Fixed a big memory leak on display of PNG images (attached to a message) as tabs.
[-] (#0005062) Folder colour groups were ignored while dragging and dropping on the tree
[-] (#0005068) The Bat! was losing one character per line decoding MIME Base64 multiline header (coded incorrectly)
[-] (#0004982) Wrong warning was displayed when adding new header field with no RFC name filled
[*] US-ASCII charset is now equal to the current windows locale
[*] Pronunciation of Folder fields
Сообщение Terrogen » Сб сен 03, 2005 8:59 pm
Выложена бета новой версии почтовой программы от RITLABS - <a href='http://www.ritlabs.com/download/files3/the_bat/beta/tb36202.rar' target='_blank'>The Bat! 3.61.02 Beta (только EXE) [3.84M]</a>, вот изменения новой версии
[*] base64-decoding is now significantly faster
[-] (#0003403) MAPIAddress with >1 nRecips/lpRecips caused TB! to return MAPI_E_FAILURE
[-] (#0005073) All user defined items have the same caption in the same container
[-] (#0005042) Item added to menu cannot be hidden
[+] New colour selections for selected states in colour groups
[*] The speed of decoding MIME Base64 has significally improved.
Вернуться в Новости софта
