WinRAR 3.50 Beta 1
Сообщение Terrogen » Чт мар 31, 2005 10:12 pm
Вышла новая бета WinRAR 3.50 Beta 1
Для тех, кто танкист - архиватор с отличным сжатием, запаковывает в RAR/ZIP и открывает 7Z, ACE, ARJ, BZ2, CAB, GZ, ISO, JAR, LZH, TAR, UUE, Z. <!--emo&:)-->[img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]<!--endemo-->
<a href='http://rarlab.com/download.htm' target='_blank'>страница загрузки</a>
Сообщение Terrogen » Пт апр 01, 2005 5:38 pm
Latest Changes:
* Change WinRAR's look by installing interface themes
* Supports decompression of ZIP archives created using Zip64 format extension
* Added support of multivolume (multipart) CAB archives
* New options in "Advanced" part of archiving dialog: ' "Delete archive" options allow to delete extracted archives ' and ' "Check authenticity information" option controls processing of authenticity information in RAR archives '
* "Wait if other WinRAR copies are active" option in "Advanced" parts of archiving and extraction dialogs
* SFX modules are not compressed by UPX anymore
* The default SFX logo can be replaced by a custom bitmap file
* It is possible to specify user defined SFX icons larger than 32x32 and with any color depth
* DOS.SFX module moved to RAR/DOS32 distributive
* "Wizard" command allows to specify a password when creating or updating an archive
* Now it is possible to define file masks to unpack everything for
* Additional file name extensions for archive formats supported by WinRAR can be specified in the "User defined archive extensions" field on the "Integration" page of the "Settings" dialog
* New "Show encrypted or compressed NTFS files in color" option in "File list" page of "Settings" dialog
* New "Lock toolbars" option in "General" page of "Settings" dialog and in the menu displayed after clicking the right mouse button on the toolbar
* "Repair" and "Extract" commands replace invalid characters (colon, question mark, etc.) by underscore also in file names in ZIP archives
* New -n and -n@ switches set additional include filters, so only files matching the mask will be processed
* New -id[c,d,p,q] switch
* Switch -e+ allows to specify file include attributes mask
* Switch -ver[n] supports the optional 'n' parameter also when archiving
* If the short name of an already existing file is equal to the long name of an unpacking file, WinRAR changes the short name of the already existing file before unpacking
* Security changes: WinRAR shell does not allow to run *.pif files
* Security changes: WinRAR shell does not allow to run files having 5 or more continuous spaces in the name
[offer]
* In Windows XP WinRAR highlights the sorted column in the file list using the different color, like it is done in Windows Explore
Сообщение Terrogen » Вт май 10, 2005 6:23 pm
<a href='http://rarlab.com/rar/wrar35b4.exe' target='_blank'>winrar3.50 beta4</a>
In this new version, WinRAR 3.50 beta 4 has got some bugs fixed:
a) internal viewer always used the default WinRAR icon regardless of the selected theme.
<!--emo&B)-->[img]style_emoticons/<#EMO_DIR#>/cool.gif[/img]<!--endemo--> buttons at the bottom of "Find" window positioned incorrectly when resizing this window and using a non-default theme.
c) rename command did not work for archived files having 5 or more continuous spaces in the name.
Сообщение sir_graf » Вт май 10, 2005 7:26 pm
Ну чэньджес вроде немало - даже скачать можно.
sir_graf
Сообщение Bom » Пт июн 10, 2005 6:10 am
Вышла версия WinRAR 3.50 beta 5
<a href='http://www.rarlab.com/rar/wrar35b5.exe' target='_blank'>http://www.rarlab.com/rar/wrar35b5.exe</a>
Также есть русская 3.50 beta 4
<a href='http://www.rarlab.com/rar/wrar35b4ru.exe' target='_blank'>http://www.rarlab.com/rar/wrar35b4ru.exe</a>
RAR - What's new in the latest version Version 3.50 beta 5
1. WinRAR is able to integrate to Windows context menus also on Windows x64 systems.
2. "Repair" command is able to reconstruct archive headers structure in archives containing the high precision file time or encrypted file data even if they do not have the recovery record.
Previously "Repair" worked for such archives only if they contained the recovery record.
3. Bugs fixed:
a) in Windows XP and 200x after turning "Show Password" option on and off the password dialog used a wrong symbol (asterisk instead of big dot) to display entered characters;
<!--emo&B)-->[img]style_emoticons/<#EMO_DIR#>/cool.gif[/img]<!--endemo--> RAR returned the zero exit code (success) after issuing "You need to start extraction from a previous volume to unpack the file" warning. It returns 1 (warning) code now.
Юрий Бомштейн
Bom
Сообщение Spike » Пт июн 10, 2005 6:17 am
Функция "Repair"...
Сколько раз пытался ей пользоваться для лечения битых архивов - все мимо. Единсвеный раз относительно помогла, когда я 70-меговый архив с мп3 альбомом восстанавливал. Первые три трека вытащил...
RUSnet #foobar2000 #miranda.
Spike
Сообщение DruG » Пт июн 10, 2005 6:31 am
<!--QuoteBegin-Spike+Jun 10 2005, 13:17--><div class='quotetop'>QUOTE(Spike @ Jun 10 2005, 13:17)</div><div class='quotemain'><!--QuoteEBegin-->Сколько раз пытался ей пользоваться для лечения битых архивов<!--QuoteEnd--></div><!--QuoteEEnd-->а инфа для восстановления была или как?
интересно много отличий от 4 бетки, стоит ли качать? да и кхм-кхм-кхм наверное исчо не появился...
Сообщение Spike » Пт июн 10, 2005 6:40 am
<!--QuoteBegin-DruG+Jun 10 2005, 13:31--><div class='quotetop'>QUOTE(DruG @ Jun 10 2005, 13:31)</div><div class='quotemain'><!--QuoteEBegin-->а инфа для восстановления была или как?
[right][snapback]177756[/snapback][/right]
Понятия не имею <!--emo&:)-->[img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]<!--endemo-->. 99% что не было, потому как я с фтпишника krYss'а качал, это был альбом ЮГов, по моей просьбе Сырок их выкладывал...
Да не суть важно, ИМХО. Или нет?
Последний раз редактировалось Spike Пт июн 10, 2005 6:40 am, всего редактировалось 1 раз.
Spike
Сообщение DruG » Пт июн 10, 2005 7:31 am
без инфы - восстановить ничего не получится, а вот хотя бы 10% это что то да значит, были моменты когда и я чего-то восстанавливал нужное, ну не ехе разумеется, но доки какие то дипломные точно были
Сообщение Terrogen » Пт июн 10, 2005 4:08 pm
2DruG
появился
Сообщение DruG » Вт июн 14, 2005 2:05 am
2Terrogen всё равно не хочу качать... подожду хотя бы 6 бетки
Сообщение Bom » Чт июн 16, 2005 10:22 am
Теперь есть <span style='color:red'>РУССКАЯ</span> 3.50 beta <span style='color:red'>5</span>
<a href='http://www.rarlab.com/rar/wrar35b5ru.exe' target='_blank'>http://www.rarlab.com/rar/wrar35b5ru.exe</a>
Юрий Бомштейн
Bom
Вернуться в Новости софта
