Terrogen » Сб ноя 13, 2004 4:56 am
Opera for Windows without Java 7.60 Build 7321 Preview 3
Latest Changes:
* Removed Internet suite/Browser only selection from start-up procedure and made messaging client integration dynamic
* Added a choice between Prefer pages inside window (tabs), Separate windows (SDI), and Advanced MDI in Preferences > Windows
* The Start bar for blank pages now drops down from the URL field
* Favicons for bookmarks work again
* Notification tooltips will now appear where the System tray is, usually in the bottom right of the screen
* Fixed a problem preventing toolbars from being enabled if their placement had been set to off
* Fixed a crash that occurred when opening a new window if the Page bar placement wasn't set to top
* Added Ctrl + F12 and Shift + F12 as keyboard shortcuts for the Preferences and Customize dialogs, respectively
* Moved Customize to View > Toolbars menu
* Q focuses quick reply if focus was on message list
* Added Use current button for home page preference in Preferences > Start and exit
* Improvements to scrolling
* Activated ERA (Extensible Rendering Architecture), enabled by selecting Fit to width from the View menu
* Printing now defaults to Fit to width (disable in File > Print options)
* Multiple rendering fixes
* Trigger quirks mode to render pages using the IBM doctype correctly
* Made {button} look more like {input type=button}
* The prefix browser is now mandatory for all commands directed at the Opera interface, to avoid problems with pages written in X+V
* Unchecking Enable sound in Web pages in Preferences > Multimedia/Quick preferences will now disable Voice
* Made sure that the newsfeed name is not left empty when clicking on a feed and subscribing to it
* Fix to avoid duplicate newsfeed items
* Preliminary support for links/URLs using irc://
* Fixed preview 2 problem where clicking the CC button would add input to the "To:" field
* Reenabled saving of chats
* Made threading toggle into a single button
* Multiple stability fixes
* Multiple scripting improvements and fixes
* Fixed several cursor issues
* Preview 2 Wand auto-login regression fixed
* Improved handling of DDE URLs
* Added support for INI files with escapes (similar to LNG files)
* Added support for the FTP command EPSV
* Fixed problem where local URLs containing con could not be opened
<a href='http://snapshot.opera.com/windows/o760p3_7321.exe' target='_blank'>скачать</a>
