The Bat! 2.11 Final
Сообщение Bes » Ср июн 02, 2004 4:23 am
В очередной раз длинную колонну из бета-версий известного почтового клиента замкнул финальный релиз. Добавлены фичи, пофиксены баги. Все рады и счастливы. Изображение
What's new:<!--QuoteBegin--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>Цитата </td></tr><tr><td id='QUOTE'><!--QuoteEBegin-->[+] Mail Chat (Tools|Mail Chat)
[+] Chat Virtual folders for watching conversation threads or waiting for replies to specific messages
[+] "Utilities|Create a Quick Template" menu command in the message editor to quickly create a QT based on the selected text
[+] (#0001869) New Window Split Mode - Full-width Message List
[+] Automatic filtering on IMAP
[+] Customizable hotkeys for next/prev folder tab (Edit shortcuts/MainMenu/Specials)
[+] It is now possible to re-filter only selected messages
[+] Message Editor (using MicroEd) has new status - AutoFormat, AutoWrap, JustifyOnWrap, AutoSpell
[+] Possibility to insert a line divider in HTML editor
[+] URLs of incoming messages are added to the log
[+] Possibility to open URLs by double click from the account's log viewer
[+] Smartpad.ini: [Options] Taskbar = 1 - shows smartpad in taskbar
[+] Support of Images\PDSF.MSL file for translating smileys (see the Beta distribution file)
[+] VF message DblClk - opens VF folder view; Ctrl+DblClk - Follows message; Shift+DblClk - opens folder view
[+] Viewing account's log window is no longer modal
[*] (#0001307) Tab order in the Folder Maintenance Centre is now working more correctly
[*] (#0002992) UTF-7/8 decoding is now much faster
[*] It is now possible to log manual refiltering
[*] Search options in the Accont Log View pop-up menu
[*] The current folder was removed from the Unread tab when new mail was received
[-] (#0001633) Character set detection bug in PGP/MIME messages
[-] (#0001742) Unread messages were loaded and treated as read during refiltering process
[-] (#0002259) Embedded image files were multiplicated at each [auto] save
[-] (#0002653) Account tree nodes' states were not stored correctly
[-] (#0002673) Selected shortcuts for Send/Queue in the message editor weren't remembered
[-] (#0002716) Access Violation error while search in a deleted folder
[-] (#0002764) The "l" LDAP attribute was not processed
[-] (#0002922) Deleted messages counters were not updated in the Folder Maintenance Centre
[-] (#0002951) Access Violation error when selecting folders for search in message reminder
[-] (#0002955) Generic view mode setting is not saved, previous setting is used after restart
[-] (#0002972) Account tree expand, when you open the account properties
[-] (#0002997) Split mode - full width msg list - msg preview toggle one way
[-] (#0003005) Virtual Folders think they're Normal Folders is VF name and Directory are not the same
[-] (#0003026) Option "Edit | Select all" doesn't work in HTML editor, Ctrl+A works
[-] (#0003027) MessageFinder does not "Follow"
[-] (#0003038) Using "IMAP Folder management" deletes account level VFs
[-] IMAP folder management could fail to see some folders on some IMAP servers
[-] No duplicates of message in chat folders
[-] Some other minor fixes<!--QuoteEnd--></td></tr></table><div class='postcolor'><!--QuoteEEnd-->
<a href='http://www.ritlabs.com/download/files3/the_bat/the_bat2.11.00.exe' target='_blank'>Скачать</a> (3,9 Мб).
Самая лучшая подпись!
Bes
Вернуться в Новости софта
