Очередной релиз кандидат четвертой версии Zoom Player.
What's new:<!--QuoteBegin--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>Цитата </td></tr><tr><td id='QUOTE'><!--QuoteEBegin-->* VMR7 support added to Standard Media Mode and Customized DVD Mode.
* New Entry (Advanced Options / Values / Other) allowing you to Auto-Get the duration of Media Files according to file extensions. The default is not to Auto-Get as this slows down loading of play lists, however an entry of "AVI;MP3;MPA;OGG" won't slow it too much.
* New Setting (Advanced Options / Control Bar / Settings) allowing you to have the Control Bar always visible when playing an Audio file in fullscreen.
+ A Zoom Player WMV Professional key will now activate WMV features on the Zoom Player Professional executable and using a Zoom Player Professional key on the Zoom Player WMV Professional executable will only enable the Zoom Player Professional feature-set.
+ Slight change to the top-buttons on the media mode skin.
+ Further expansion and stability of the TCP/SendMessage interface.
+ The Filters in use Customized Media Mode listing now shows the registration state for the selected profiles.
+ Going fullscreen now moves the Zoom Player window to the front.
- Possible fix to AC3 Filter connection issues.
- Auto Segment Loading could incorrectly match non-media files (such as subtitle files with the same base name).
- Mouse wheel would not work properly when the play list editor window was visible before going to fullscreen.
- Certain Flash files could lose audio when resizing window.
- Loop current media file feature could cause a crash when playing non-DirectShow content (HTML/QuickTime/JPEG/Etc...).
- Unicode file names will now show properly on the application task bar (when the setting is enabled under Options / Settings / Other).
- Tab switching in options dialog is now more logical.<!--QuoteEnd--></td></tr></table><div class='postcolor'><!--QuoteEEnd-->
<a href='http://www.inmatrix.com/download/zoomplayer400rc3std.exe' target='_blank'>Скачать</a> Standart (995 KB - Freeware).
<a href='http://www.inmatrix.com/download/zoomplayer400rc3pro.exe' target='_blank'>Скачать</a> Pro (1.03 MB - Shareware).
<a href='http://www.inmatrix.com/download/zoomplayer400rc3wmvpro.exe' target='_blank'>Скачать</a> WMV Pro (1.03 MB - Shareware).
