Помогите пожалуйста сделать случайное удаление из списка. Вот изначальный код:
#include <iostream.h>
struct node
{ char name[20]; // Name of up to 20 letters
node *nxt;// Pointer to next node
node *start_ptr = NULL;
node *current; // Used to move along the list
int option = 0;
void add_node_at_end()
{ node *temp, *temp2; // Temporary pointers
// Reserve space for new node and fill it with data
temp = new node;
cout << "Please enter the name of the channel: ";
cin >> temp->name;
temp->nxt = NULL;
// Set up link to this node
if (start_ptr == NULL)
{ start_ptr = temp;
current = start_ptr;
else
{ temp2 = start_ptr;
// We know this is not NULL - list not empty!
while (temp2->nxt != NULL)
{ temp2 = temp2->nxt;
// Move to next link in chain
temp2->nxt = temp;
void display_list()
{ node *temp;
temp = start_ptr;
cout << endl;
if (temp == NULL)
cout << "The list is empty!" << endl;
else
{ while (temp != NULL)
{ // Display details for what temp points to
cout << "Name : " << temp->name << " ";
/* cout << "Age : " << temp->age << " ";
cout << "Height : " << temp->height; */
if (temp == current)
cout << " <-- Current node";
cout << endl;
temp = temp->nxt;
cout << "End of list!" << endl;
void delete_end_node()
{ node *temp1, *temp2;
else
{ temp1 = start_ptr;
if (temp1->nxt == NULL)
{ delete temp1;
start_ptr = NULL;
else
{ while (temp1->nxt != NULL)
{ temp2 = temp1;
temp1 = temp1->nxt;
delete temp1;
temp2->nxt = NULL;
void main()
{ start_ptr = NULL;
do
display_list();
cout << endl;
cout << "Please select an option : " << endl;
cout << "0. Exit the program." << endl;
cout << "1. Add a TV channel to the end of the list." << endl;
cout << "2. Delete the last TV channel from the list." << endl;
cout << endl << " >> ";
cin >> option;
switch (option)
case 1 : add_node_at_end(); break;
case 3 : delete_end_node(); break;
while (option != 0);
