Wincmd 5.10 Final
Wincmd 5.10 Final
Сообщение Jazzy$ » Пт авг 30, 2002 6:44 am
Всем доброго!
собственно subj.
брать здесь:
<a href='http://download.server2.come2store.com/samsoom66/Eatwc510.zip' target='_blank'>http://download.server2.come2store.com/sam...66/Eatwc510.zip</a>
это линк на страницу. в этом зипе 2 версии 16 и 32 битная, обе зарегены.
Удачи...
Jazzy$
Сообщение Hazy » Пт авг 30, 2002 8:32 am
С закачкой конкретные траблы. Подхватилось только из Internet Explorer в связке с ReGet. Во как.
28.08.02 Release Wincmd 5.10 Final
27.08.02 Fixed: When copying to removable NTFS volume, don't call "Flush" every xx seconds (causing problems with preallocation)
22.08.02 Fixed: Installer hangs if any of the target files has the hidden attribute
21.08.02 Release Wincmd 5.10 RC1
20.08.02 Fixed: Diskdir plugin: Extract file date/time with files
20.08.02 Fixed: Ctrl+B Branch view: Drag file from subdir with spaces in it to button bar button would not open the file
20.08.02 Fixed: FTP: When editing a file with F4, then disconnecting and reconnecting to other server, the file was re-uploaded to the wrong server
14.08.02 Release Wincmd 5.10 Beta 2
14.08.02 Fixed: Crash on Alt+Enter if WinRAR 3 installed
13.08.02 Fixed: Moved creation of sound registry keys to configuration dialog - only if "Configure sounds" button is clicked
12.08.02 Fixed: Make Wincmd work with current RAR.EXE version (Winrar.exe already worked, use this if possible)
07.08.02 Fixed: Shift+Enter didn't work inside of archives
07.08.02 Fixed: "Show (Lister)" no longer working in context menu
06.08.02 Release Wincmd 5.10 Beta 1
06.08.02 Fixed: Parameter %P in button bar: Remove "0:" pseudo drive for ftp connections
04.08.02 Fixed: Search function unpacked ACE archives even when it didn't search for text
30.07.02 Fixed: Compare by contents: If one listbox has a horizonal scrollbar and the other hasn't, scrolling to the end brings lists out of sync
30.07.02 Fixed: User-defined hotkeys didn't work with RestrictInterface=1 (turning off the start menu)
28.07.02 Added: Support for TAR files >2GB (the individual packed files must be smaller than 2 GB!)
28.07.02 Fixed: On Win9x+ME, the parallel port driver cannot be loaded if the directory contains a non-English accented character -> copy driver temporarily to system directory
28.07.02 Fixed: Parameter /L=//servername/ didn't work, only /L=//servername/share
26.07.02 Fixed: Shift+F4 (new file) didn't work if editor was defined with "%1" parameter
26.07.02 Added: Translate environment variables in the command line, e.g. cd %windir% -> cd c:windows
26.07.02 Fixed: Right click on drive button and choosing a command from the 'New' submenu sometimes created the new item in the current directory
23.07.02 Fixed: WinXP shows other computers in Nethood subdirs in the form "Server Comment (servername)". Changed to "servername".
23.07.02 Fixed: When unpacking to temp dir on ENTER, remove read-only attribute so file can be deleted later
19.07.02 Fixed: FTP: access violation if local name too long
19.07.02 Fixed: Sync tool: German 'sz' letter was detected as being the same as 'ss' in sync tool ('feature' of the 'CompareString' function of Windows...)
19.07.02 Fixed: background transfer manager: Total length of source+target dir couldn't exceed 259 characters
02.07.02 Fixed: Compare by content, if file too big, the file handle wasn't always closed after compare failed
25.06.02 Fixed: Configuration dialog, when changing fonts, the preview shows the wrong fonts after clicking "Apply"
25.06.02 Added: On FTP downloads, replace colon ":" by underscore "_" because otherwise Windows creates a named substream on NTFS
20.06.02 Added: Command line during FTP connection: "PUT" command now supports absolute paths, e.g. PUT c:filesfile.txt
18.06.02 Fixed: Creating multi-volume ZIP archives slow on Win2k
18.06.02 Fixed: Background transfer manager: "-" button removed wrong items from list if already downloaded a file
18.06.02 Fixed: Show file sizes >2 GB also in overwrite confirmation dialog
11.06.02 Fixed: Parallel port server in Wincmd16: Could not access empty drives (e.g. floppy with no files)
11.06.02 Fixed: Command line: Forward slashes will now be converted to backslashes on local drives
31.05.02 Fixed: Selection with Shift+Left click didn't always work after selecting first item with right click
31.05.02 Added: Synchronize dirs: Total % of comparison now calculated by file size, not number of files
31.05.02 Added: Support for <XMP> tag in lister (same as <PRE>)
31.05.02 Fixed: In place rename in ZIP can now also be invoked by a slow double click
31.05.02 Added: Search for multiple paths in search function now also works with UNC paths, e.g. servershare1;servershare2
29.05.02 Added: FTP: When using auto-retry, also wait for the retry timeout after the first connection attempt
14.05.02 Added: SHA1 authentication to FTP client
14.05.02 Fixed: Drag other window over drive button bar could show frame
14.05.02 Fixed: In the button bar, a button was shown as down after right clicking on it
13.05.02 Added: FTP client will send FEAT command to ask for ftp server features MDTM and LIST -lT (full date/time display)
10.05.02 Added: FTP client: Upload/download files > 4 GB, also with resume
05.05.02 Fixed: Lister standalone: Mouse scrolling didn't work
17.04.02 Fixed: After changing attributes in subdirs, the current selection wasn't removed if nothing had changed in the current directory
17.04.02 Added: Also copy date/time of IStream objects on drag&drop (doesn't work with Outlook Express, because OE doesn't pass them)
17.04.02 Fixed: Zip subdir was removed when clicking "encrypt" in pack dialog
17.04.02 Fixed: Compare by contents could fail with a single character at the end
16.04.02 Added: Internal unpacking of single files from multi-volume RAR archives (requires new unrar.dll)
16.04.02 Fixed: Multi-volume RAR files: Only show files which start in that volume!
16.04.02 Fixed: Support for new multi-volume RAR files (requires external winrar for unpacking)
15.04.02 Fixed: Problem with copying huge files using the special copying modes
15.04.02 Fixed: Pausing a HTTP download moved to the background also paused a foreground ftp download
15.04.02 Fixed: No error messages when trying to compare a file on an ftp server, or copying from ftp to an archive
15.04.02 Fixed: FTP download later: didn't save firewall type for http firewalls
15.04.02 Added: Support for bmp files with negative height (stored upside down)
15.04.02 Added: Support for *.jp2 and *.j2k (Jpeg 2000) through Irfanview
15.04.02 Added: Open link (*.lnk) in other window with Ctrl+Right arrow (or left arrow, respectively)
15.04.02 Fixed: Background transfer manager didn't remember max. transfer speed during multiple http downloads or ftp via http downloads
15.04.02 Added: Timeout to "Download complete" message from ftp server - Wincmd should try to continue if no reply for 15 seconds
25.03.02 Fixed: By mistake, quotation marks were removed from command line parameters of 2 character commands.
25.03.02 Fixed: Ctrl+B in packer plugin: Extract of files from subdirs didn't work (because subdir wasn't created)
25.03.02 Fixed: Background transfer manager didn't rename files on same drive, instead it copied+deleted them
25.03.02 Fixed: Check for a colon ":" when copying/moving with F5 or F6 to avoid the copying of the data to a named substream
25.03.02 Fixed: Explicitely check for a colon ":" when renaming with Shift+F6 to avoid moving the data to a named substream on NTFS drives
25.03.02 Fixed: If deletion of non-empty dir is canceled, the dir loses any special attributes like hidden or system
11.03.02 Fixed: Problems with internal HTML links without double quotes
05.03.02 Fixed: Don't get special icons for folders with read-only attribute on UNC network drives
28.02.02 Fixed: FTP transfer log sometimes contained duplicate slashes in URLs
25.02.02 Fixed: Couldn't copy file on remote share to other dir with file of same name
25.02.02 Fixed: Extension was removed from xyztar.zip when clicking on 'create self-extracting archive' in pack dialog
15.02.02 Added: Support for OTP secure FTP authentication (not encryption!), e.g. for Serv-U, supports MD4 and MD5 (not working through all proxies)
Hazy
Сообщение zmich » Пт авг 30, 2002 9:06 am
<a href='http://www.moneys2008.com/down/eindex.php' target='_blank'>http://www.moneys2008.com/down/eindex.php</a>
Хотя может приведет на ту же ссылку...
Я качал отсюда -крэк в исполнении EAT
zmich
Сообщение Trasher » Пт авг 30, 2002 4:54 pm
Закачал 5.10 с wincmd.ru обычным способом,
тока вот лекарства пока нигде не нашел.
Может подскажет кто?
Memento mori...
Memento mori...
veni vidi vici
Trasher
Сообщение Гость » Сб авг 31, 2002 4:30 am
Берите <a href='http://www.zuul.info/acedown/download.php?act=soft&sid=510&uid=1' target='_blank'>здесь</a>, уже крякнутая.
Гость
Сообщение Rulchik » Сб авг 31, 2002 6:42 pm
To: ALL
[size=18]<span style='color:red'>Господа! Все вопросы/ссылки по крякам - в Варез!!!</span>
Rulchik
Сообщение VanyaS » Вс сен 01, 2002 3:43 am
Есть уже готовый key-файл, кому надо, пишите, вышлю.
VanyaS
Сообщение Мытя » Вс сен 01, 2002 2:45 pm
Trasher
Не крякай! Зачем?
С утра открой Windows Commander, один раз нажми на 1-3 и до вечера.
Мытя
Сообщение zmich » Пн сен 02, 2002 11:06 am
Сегодня (02.09) ключ на nnm.ru в разделе filez...
zmich
Сообщение zmich » Пн сен 02, 2002 4:19 pm
Народ а русский от 5.0 подходит к 5.10?
zmich
Сообщение Мытя » Пн сен 02, 2002 5:44 pm
zmich
Конечно.
Мытя
Сообщение Hazy » Пн сен 02, 2002 7:14 pm
zmich
на офсайте WC уже есть руссификатор для 5.10
Hazy
Вот кусок из оффициального форума WC
Сообщение Jazzy$ » Вт сен 03, 2002 6:36 am
Why 5.1 and not 5.5? In the last few weeks, I got a lot of e-mails why Wincmd cannot unpack RAR3 archives. Therefore I decided to release an interim update 5.1 which contains the new Unrar.dll and which fixes a lot of small problems found during the last half year. Since the big new features (RTF viewer, file comments, file system plugins) still need considerable work, I postponed them to version 5.5, which is planned for this Autumn.
Jazzy$
Сообщение renreg » Ср сен 04, 2002 5:27 am
Jazzy$
Приятная новость
Заграница нам поможет
renreg
renreg
Сообщение Hazy » Ср сен 04, 2002 6:38 am
новость то приятная, только средствами WC с настроиным RAR на распаковку ZIP так и неработает.
Hazy
