Новая версия Total Commander
Сообщение SunSeth » Пт янв 26, 2007 10:19 am
вот така паганая семерка...
SunSeth
Сообщение Dutchman » Пт янв 26, 2007 11:25 am
О! огромное спасибо- работает :)
Dutchman
Сообщение -=NV=- » Пт янв 26, 2007 1:07 pm
Dutchman, :)
ибо нефиг гнать на глюкавый ТС :)
-=NV=-
Сообщение Dutchman » Пт янв 26, 2007 2:01 pm
Дык я чё- я ничё- работает говорю :)
Dutchman
Сообщение -=NV=- » Вт май 29, 2007 9:00 am
TC RC5
<!--quoteo--><div class='quotetop'>Цитата</div><div class='quotemain'><!--quotec-->24.05.07 Release Total Commander 7.0 release candidate 5 (RC5)
24.05.07 Fixed: Minor fixes to help, translations and history
22.05.07 Release Total Commander 7.0 release candidate 5 (RC5) pre1
22.05.07 Fixed: Installer: 2 dialogs didn't have a close button in the title bar
22.05.07 Fixed: Compare editor called from synchronize dirs with file in archive subdirectory, modify file -> Re-packing packed to root instead of the correct subdir (for packer plugins only, was fixed previously for internal packers)
22.05.07 Fixed: Change attributes: Move focus to Plugin attributes checkbox if user chooses something from the dropdown combobox and no plugin options are shown
22.05.07 Fixed: Changed default title of background transfer manager from "Transfer" to "Total Commander". This title is only shown as long as no title is set
22.05.07 Fixed: Delete function: User chooses "Skip all" when a file cannot be deleted -> do not warn any more also for directories which cannot be deleted
22.05.07 Fixed: Copy function: If the user has chosen "Skip all", running programs and open files were not skipped automatically
22.05.07 Fixed: cm_SyncChangeDir mode: If the active side shows the contents of an archive, the directory on the other side was only changed when it was written exactly the same (upper-/lowercase)
22.05.07 Fixed: Unicode warning dialog: The dialog was turned off also when the user checked to no longer show it, but then clicked on "Cancel"
21.05.07 Fixed: Compare editor: When comparing a file from an archive, do not offer to re-pack if the user saved the file to a different name than the original (save as), only when the original was modified
21.05.07 Fixed: Custom field [tc.size] could be shown as <DIR> in thumbnail view for 0 byte files
18.05.07 Fixed: Search function: ESC in any other program would abort unpacking of files for searching text in archives
18.05.07 Fixed: Configuration - Packer: Let the user save double quotes around name (they must be stored TWICE in wincmd.ini because Windows removes one pair of "")
18.05.07 Fixed: Compare by content: Remove direction arrow (shown when invoked from overwrite dialog) when choosing different file
18.05.07 Fixed: FTP upload in background: <PAUSED> was not translated
16.05.07 Fixed: Compare by content: Right listbox too wide after switching from vertical to horizontal arrangement
15.05.07 Release Total Commander 7.0 not public release candidate 4.5 (RC4.5)
15.05.07 Fixed: Synchronize dirs: Focus loss when using external packer (WinXP only)
15.05.07 Fixed: Lister: Place cursor behind selection on double click or triple click
15.05.07 Added: When opening a file from inside an archive, only show the dialog "Click on Close when the temporary file can be deleted!" when either the focus is not on TC, or it is on TC but never went away from it. Should avoid the dialog if a user closes a viewer very quickly.
15.05.07 Fixed: When opening a .tab file containing no tabs with Shift+Enter (=replace), the tab headers would become completely empty, but would not be removed
15.05.07 Fixed: Internal ZIP packer: Sometimes no second percent bar during verify on Windows 9x (timing problem)
15.05.07 Fixed: Drag&Drop of OLE data to Total Commander (e.g. address line from IE/Firefox): Allow to overwrite read only/hidden/system files (with warning), show error if copying fails
13.05.07 Fixed: Directory with & character at the end was shown incorrectly in the folder Tab bar. The & was converted to an underline _ by Windows.
13.05.07 Fixed: Could not list UC2 archive containing ^ sign in the file name or path name
13.05.07 Fixed: Multi-rename tool: Also keep comments in complex rename situations, e.g. 1->2 2->3 3->4 etc.
13.05.07 Fixed: Synchronize dirs: Selection in main program was cleared after using external pack tool -> no results shown if "only selected" was checked
11.05.07 Added: Compare by contents: If invoked from overwrite dialog, show file to be copied on left side, and show arrow with copy direction
11.05.07 Fixed: Compare editor: Changes not saved when closing Total Commander
11.05.07 Fixed: Compare editor: Could no longer delete lines near end of file after last fixes
10.05.07 Fixed: Compare editor: In some special cases, a line could appear twice in a file
10.05.07 Added: Increased possible number of packer plugin extensions to approx. 250.
10.05.07 Added: Compare editor: Ctrl+Home also moves to beginning of the first line, Ctrl+End to the end of the last
10.05.07 Fixed: Compare editor: Fix cursor position after click on "Compare"
10.05.07 Fixed: ZIP unpacker: Couldn't handle files >4 GB in ZIP archives created by DynaZip (where only the original size was stored in 64 bit, not the packed size)
09.05.07 Fixed: Synchronize dirs, quick search: Sometimes 2 lines were selected after leaving quick search
09.05.07 Fixed: Search for UTF8 no longer working in search function (but worked in lister)
09.05.07 Fixed: Compare editor: Ignore Delete on not present lines if the next line is also not present
09.05.07 Fixed: Compare editor: Save as: Incorrect name given when no extension was specified, and the original file had no extension either
09.05.07 Fixed: Compare editor: Update both sides of Total Commander after saving file
08.05.07 Fixed: Compare editor: Don't react to Alt+Backspace or Ctrl+Z if Undo button is disabled
08.05.07 Fixed: Compare editor: Remove any selection when clicking on "Compare" to recompare the files (also in edit mode)
08.05.07 Fixed: Compare editor: If nothing is selected and one of the Copy text button is clicked, only copy the current line if the "from" window is currently active
08.05.07 Added: Show native 24x24 icons in button bar and main menu also on Windows 9x/ME
08.05.07 Added: Hint and overwrite dialog custom fields: Support field contents not containing any plugin fields, e.g. to show a fixed text for a specific file type
08.05.07 Fixed: Windows XP 64: If redirection of system32 folder is turned off, it will be temporarily re-enabled while checking the presence of the Network Neighborhood
07.05.07 Fixed: Compare editor: Cursor on a line only existing on the other side, Alt+Cursor, Undo, Alt+Cursor, Undo -> invalid Undo
07.05.07 Fixed: Compare editor: After Undo, a non-existing empty line could remain
07.05.07 Fixed: Compare editor: Ctrl+Arrow keys not working in lines which exist only in the other panel
06.05.07 Added: Include extended wcmicons.dll (without the 48x48 icons) in the default installation
06.05.07 Fixed: Compare editor: After Undo, the cursor was sometimes placed on the wrong character
06.05.07 Fixed: Compare editor: Still problems with pressing ENTER beyond the last line of the shorter file
06.05.07 Fixed: Compare editor: Cursor wasn't scrolled into view on Home/End/Ctrl+Left/Ctrl+Right
06.05.07 Fixed: Right click - "New" submenu: Didn't place cursor on new file if the "ShellNew" entry in the registry used the "Data" key value to initialize the new file
06.05.07 Fixed: Compare by contents: Do not turn off right vertical scrollbar when switching horizontal/vertical view modes
06.05.07 Fixed: Removed Help button hotkey from multiple English dialogs (F1 is sufficient for help)<!--QuoteEnd--></div><!--QuoteEEnd-->
Последний раз редактировалось -=NV=- Вт май 29, 2007 7:37 pm, всего редактировалось 1 раз.
-=NV=-
Сообщение NickFW » Ср май 30, 2007 7:59 am
-=NV=-,
а дай линк, где дёрнуть... я чёт поискал пока не нашёл...
Сообщение Helg » Пт июн 08, 2007 10:18 am
TC version 7.0 realised
dum spiro spero
Helg
Сообщение -=NV=- » Пт июн 08, 2007 10:38 am
NickFW писал(а):-=NV=-,
_http://fileforum.betanews.com/sendfile/945901171/1/tcmdr700.exe
_http://download.samlab.ws/tcpp/total_commander_powerpack_russian_pro.zip (7.00 rc5 powerpack pro)
-=NV=-
Сообщение NickFW » Пт июн 08, 2007 3:15 pm
-=NV=-,
сеньк, завтра солью на работе...
Сообщение maxovt » Пт июн 08, 2007 5:46 pm
NickFW, неужели с фары слез? :o
Сообщение NickFW » Сб июн 09, 2007 12:14 am
maxovt,
есть не много... но т.к. ТЦ упорно отказывается работать в качестве ФТПшника и ни кто пока так и не подсказал всчём собака зарыта, FAR юзаю для ФТП, но тотал у меня раскрашет в теже цвета что и фар, ибо знаешь 12 лет привычки к одной и тойже раскраске файла... я просто не смотрю на иконки, я привык к тому что имена файлов раскрашены в те цвета в какие должны быть... по этому у меня тоатл выглят как мне надо ;)
-=NV=-,
ещё раз сеньк за линк, пошёл качать...
Сообщение maxovt » Сб июн 09, 2007 10:53 am
Salamander тоже можно раскрасить. :rolleyes: И только его FTP-клиентом пользуюсь.
Но здесь немного другая сторона. Я после FAR'а около года на Проводнике сидел и его привычки тоже въелись, особенно привык к отображению файлов. Поэтому в Саламандре мне работа представляется более логично организованной и эстетически приятней. :)
Сейчас Тотал только для связи с телефоном юзаю. :)
