Новая версия Total Commander
Сообщение sm@rt » Вт дек 27, 2005 9:21 am
Пока что бета.
<a href='http://overclockers.ru/cgi-bin/files/download.cgi?file=8' target='_blank'>Total Commander 6.54 beta 1</a> (1.5 MB, shareware).
Что нового? Да в основном мелкие фиксы.
14.12.05 Release Total Commander 6.54 beta 1
14.12.05 Fixed: 2 Total Commander instances, left mose selection mode. Drag&Drop files/dirs with right mouse button between the two, create link -> links with wrong names created (.lnk extension missing)
14.12.05 Fixed: Explicitly set focus to current file list before closing the quick search dialog, to fix a bug in WindowBlinds 5
14.12.05 Fixed: When viewing single files with F3 or Alt+F3 and the local file already exists, use new naming scheme file.txt -> file.000.txt instead of just file.000 (e.g. for lister plugins)
11.12.05 Added: U3 support: Internal functions to ensure that TC shuts down in all cases when removing an U3 USB stick
09.12.05 Fixed: Included new unacev2.dll (security bugfix)
09.12.05 Fixed: Don't save selection within a tab when switching away from a locked tab with dir changes allowed (except when in the base dir of that tab)
30.11.05 Fixed: FTP: replace special chars ;:@&=+"#%<> by %hexcode, because some HTTP proxies (Squid!) dislike these characters in URLs
30.11.05 Fixed: FTP: trying to download very long name can cause access violation
29.11.05 Fixed: Some colors incorrect when using white on black text
25.11.05 Fixed: By mistake, all content plugins without a detect string were loaded with totalcmd! <- solution: save empty detect string to ini too!
23.11.05 Fixed: Some right to left dialogs (Hebrew, Arabic) were not shown correctly, e.g. search in plugins
22.11.05 Fixed: When adding files to a packer plugin archive with different extension than registered, TC didn't ask for overwrite. Changed plugin interface version to 2.11 to reflect this change.
22.11.05 Fixed: Status path shown incorrectly in custom columns view with LongInStatus=1
13.11.05 Added: For admins: Under HKEY_CURRENT_USER\Software\Ghisler\Total Commander\configuration, add allowed (type string) and/or RestrictInterface (type DWORD) to restrict user options. The value will be combined with the value in the ini file (the more restricted wins)
30.10.05 Fixed: Synchronize dirs with FTP: use UTC for MDTM command
30.10.05 Added: Multi-rename tool: Replace characters (returned by plugins) which are not allowed in file names by underscores or dots
21.10.05 Fixed: Ctrl+Q quick view panel: With some lister plugins like hpg_ed, F3 invoked both find next (desired) and the lister (not desired)
18.10.05 Fixed: FTP sync: additional check for ESC during upload+download
18.10.05 Fixed: Synchronize dirs: Increased the default widths of the size columns a bit (user request)
18.10.05 Fixed: Search in plugins: Go to file not working if the file name or path contained a forward slash
16.10.05 Fixed: Background transfer manager: speed limit not working when copying multiple subdirs
16.10.05 Fixed: Background transfer manager: aborting copy function not always working
11.10.05 Fixed: Disallow the creation of directories ending with spaces, e.g. "a / \ "
11.10.05 Added: Allow to delete directories and files which end with one or more spaces!
09.10.05 Fixed: Memory error in compare tool with some big files
28.09.05 Fixed: When using Letters with search dialog as quick search mode in archives with Ctrl+Q, then going to an image file can cause an access violation (because the quick search dialog is hidden by the unpack dialog)
27.09.05 Fixed: In double byte languages like Chinese, characters in zip/rar with second char '|' were shown incorrectly (because '|' is normally illegal in file names)
27.09.05 Fixed: Make FTP client work with FTP servers which return a forward slash after a directory name
27.09.05 Fixed: When browsing virtual folders, try to get the name in various ways (first for parsing, then in folder, then normal)
27.09.05 Fixed: F3 on mp3 file marked "Text" instead of "Image/Multimedia" in lister's menu
23.09.05 Fixed: Unzip: If zip file contains invalid (0) date/time, don't set it on extraction
21.09.05 Fixed: Lister: Wrong text copied in first line (unicode mode and utf8 mode)
18.09.05 Fixed: Wrong display under the following condition: Vertical arrangement, two drive button bars, then switching color depth (e.g. 16 bit -> true color)
18.09.05 Fixed: Custom columns view: "list index out of bounds" error if both sides only show name+ext, and the column width is adjusted by mouse
18.09.05 Fixed: Dual screen mode: Double click on word in Lister only selected the word on screen with positive coordinates
18.09.05 Fixed: Win9x only: Renaming not working in mode singleclickstart=1 if the mouse was moved over the file list during renaming
16.09.05 Fixed: Clicking on panel title while quick view was active did not activate the RTF viewer or a plugin inside of the quick view panel
16.09.05 Fixed: On Ctrl+U, do not set swapped tab title to locked tabs
13.09.05 Added: Command line parameters for uninstaller tcuninst.exe for silent uninstall: /r repair, /0../7 unstall. Sum of: 1=desktop icon, 2=context menu entries, 4=all settings files
25.08.05 Fixed: Button bar : no icon shown if path contained a comma
23.08.05 Added: Optimize unzip: open archive once at the beginning and keep open (necessary because of a bug in Windows XP SP2, where CloseFile over a network takes up to 2 seconds!)
10.08.05 Fixed: Synchronize dirs: Copy direction problem when synching between dir+zip in asymmetric mode and unchecked files
09.08.05 Fixed: Tree functions and creation of dirs failed if Alt+F10 tree contains paths longer than 259 characters
29.07.05 Added: On Ctrl+PageDown, TC now searches the first 512 kbytes for a valid archive header. Reason: The RAR unpacker will support themes which can contain a big uncompressed background bitmap in the unpacker...
06.07.05 Fixed: Copy speed limit wasn't enforced when opening the background transfer manually and adding files for copying AFTER checking the speed limit option
06.07.05 Fixed: Clicking on "*" button in the inactive panel added/removed the wrong directory (from the active side!)
06.07.05 Fixed: Internal unzip: forget password after operation
06.07.05 Fixed: Built-in English menu: In the "Mark" menu, two menu items had the same hotkey
06.07.05 Fixed: Changed behaviour of FTP server define dialog: Alt+Shift+Enter during a connection will keep currently used server type. OK will apply the new settings, Cancel will revert to standard type.
05.07.05 Fixed: Button bar: If parameter starts with '?' and contains one of the list parameters like %L, the temporary list wasn't deleted if the user clicked 'cancel'
05.07.05 Fixed: Ctrl+Shift+U (Swap all tabs) not working properly when a tab with "locked but dir changes allowed" was an active tab, and this tab was showing something else than the locked root dir
05.07.05 Fixed: Tab with "locked but dir changes allowed" was lost (deleted) when it was showing a search result while closing the program (only if the tab was inactive)
05.07.05 Fixed: Switch between tabs with comment view and tree view not working correctly
05.07.05 Fixed: Switch from search result view to tree view didn't change tab title from "Search result" to e.g. "c:"
05.07.05 Fixed: Don't switch from search result to full view when choosing Show-Full while showing comments in search result
Сообщение Spike » Вт дек 27, 2005 9:37 am
В закачку!
RUSnet #foobar2000 #miranda.
Spike
Сообщение Elzor » Вт дек 27, 2005 9:47 am
<!--QuoteBegin--><div class='quotetop'>QUOTE</div><div class='quotemain'><!--QuoteEBegin-->Forbidden
You don't have permission to access /system/Total_Commander_6.54_Beta 1.zip on this server.
Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request.<!--QuoteEnd--></div><!--QuoteEEnd-->
Ну че за фигня?
Elzor
Сообщение Mishail » Вт дек 27, 2005 11:20 am
На сколько я помню, распространение бета версий ТЦ запрещено, и бета-тестер уличенный в сливе, лишается статуса бета-тестера
Mishail
Сообщение SunSeth » Ср дек 28, 2005 1:16 pm
Тогда подождем релиза.
SunSeth
Сообщение sm@rt » Ср дек 28, 2005 4:14 pm
Могу выложить на рапиду или еще куда... если кому надо. Сам не ставил - бета все-таки
Сообщение Elzor » Ср дек 28, 2005 6:06 pm
2sm@rt
Выложи, только не здесь а в варезе. Распространение бет TC не легально.
Elzor
Сообщение sm@rt » Чт дек 29, 2005 8:42 am
2Elzor<!--QuoteBegin-Elzor+Dec 28 2005, 21:06--><div class='quotetop'>QUOTE(Elzor @ Dec 28 2005, 21:06)</div><div class='quotemain'><!--QuoteEBegin-->Распространение бет TC не легально.[right][snapback]195697[/snapback][/right]<!--QuoteEnd--></div><!--QuoteEEnd-->
А у тебя Винды дома нет, я так понимаю? <!--emo&:)-->[img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]<!--endemo-->)) И оффиса. И фотошопа тоже <!--emo&:)-->[img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]<!--endemo--> Ну что совсем-совсем ничего нет? <!--emo&:)-->[img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]<!--endemo-->)
Добавлено:
<a href='http://www.fforum.ru/index.php?showtopic=19867' target='_blank'>http://www.fforum.ru/index.php?showtopic=19867</a>
Последний раз редактировалось sm@rt Чт дек 29, 2005 8:48 am, всего редактировалось 1 раз.
Сообщение Elzor » Чт дек 29, 2005 8:52 am
<!--QuoteBegin-sm@rt+Dec 29 2005, 14:42--><div class='quotetop'>QUOTE(sm@rt @ Dec 29 2005, 14:42)</div><div class='quotemain'><!--QuoteEBegin-->А у тебя Винды дома нет, я так понимаю? )) И оффиса. И фотошопа тоже  Ну что совсем-совсем ничего нет? )
[right][snapback]195746[/snapback][/right]
<!--QuoteEnd--></div><!--QuoteEEnd-->Есть. Есть. Нету. <!--emo&:)-->[img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]<!--endemo-->
Не в этом дело. Я же на это ПО ссылки не выкладываю.
Elzor
Сообщение LU » Пт дек 30, 2005 9:03 am
<!--QuoteBegin-sm@rt+Dec 29 2005, 18:42--><div class='quotetop'>QUOTE(sm@rt @ Dec 29 2005, 18:42)</div><div class='quotemain'><!--QuoteEBegin-->2Elzor
А у тебя Винды дома нет, я так понимаю? :))) И оффиса. И фотошопа тоже :) Ну что совсем-совсем ничего нет? :))
нет............ совсем ничего......
из названого -))))
LU
Сообщение sm@rt » Пт дек 30, 2005 9:41 am
2LU Линуксоидом просьба не беспокоиться :) Зачем линуксоидам Тотал Коммандер. Так что тут не по теме.
Сообщение Elzor » Пт дек 30, 2005 10:11 am
<!--QuoteBegin-sm@rt+Dec 30 2005, 15:41--><div class='quotetop'>QUOTE(sm@rt @ Dec 30 2005, 15:41)</div><div class='quotemain'><!--QuoteEBegin--> Зачем линуксоидам Тотал Коммандер.
[right][snapback]195856[/snapback][/right]
<!--QuoteEnd--></div><!--QuoteEEnd--> Не сыпь мне соль на сахар. Очень жаль что там нет адекватной замены.
Elzor
Сообщение ra1n » Ср янв 11, 2006 8:05 am
Сразу же приношу извинения, наверно я маленько не в тему спрошу и скорее всего вопросы такие были. Но инет тупит ужасно и поиском не могу пользоваться.
А узнать я хотел, можно ли сделать так, чтобы ТС был установлен на флешке и работал с нее. Т.е. чтобы я подошел к новому компу, воткнул флешку и запустил настроенный мною Тотал. С нужными плагинами и др. вещами) И если это можно сделать, то как это ЛУЧШЕ сделать?
И ещё. Подскажите одну вещь.
Скажем поставил я ТС. Настроил его под себя, установил плагины, прописал любимые катологи и т.п.
Как все это сохранить можно? Т.е. чтобы при переустановке системы я не все заново настраивал а импортировал откуда нибудь файл со всеми этими настройками и все. Ну или просто как нибудь по хитрому сохранил это все..
Очень надеюсь на то что ответите.
<!--coloro:gray--><span style="color:gray"><!--/coloro-->Мне никто не нужен, мне просто скучно.. <!--colorc--></span><!--/colorc-->
<!--coloro:black--><span style="color:black"><!--/coloro--><a href="http://ra1n.rcmko.ru" target="_blank">http://ra1n.rcmko.ru</a> | r a 1 n [#] h i t v . r u | 190366146<!--colorc--></span><!--/colorc-->
ra1n
Сообщение DruiD » Ср янв 11, 2006 8:15 am
2Модеры, переместите да?
2ra1n
Все настройки, по умолчанию, хранятся в c:\windows\wincmd.ini. Для того чтобы передать ему другой файл настроек нужно запускать с параметром /i=name.ini. То есть на флэшке сделай ярлык с указанием на файл настроек на флэшке.
А в самом файле настроек замени прямые пути к плагинам на относительные с помощью алиаса %COMMANDER_PATH% который указывает на путь к тоталу. т.е. было
7z=87,C:\Program Files\totalcmd\plugins\WCX\wcx_7zip\7zip.wcx
а должно быть
%COMMANDER_PATH%\plugins\WCX\wcx_7zip\7zip.wcx
Сообщение LU » Пт фев 03, 2006 12:26 am
Релиз <a href='http://www.fforum.ru/index.php?showtopic=19867&st=0&p=198557&' target='_blank'>вышел</a> -))
LU
