Многопанельность
Сообщение Yury » Сб май 29, 2004 12:22 pm
Везде написано что в новом Total Commander 6.03a появился сабж, т.е. теперь можно открывать вместо двух сразу несколько файловых панелей.
Отлично! Однако обшарил все программу, но ничего подобного не нашел :-(
Друзья, подскажите где прячется сабж?
Спасибо.
Yury
Сообщение Evgenych » Сб май 29, 2004 12:37 pm
F1
m. Folder tabs
Tabs allow to switch quickly between multiple directories, separately for the left and right panel. Settings like the sort order, brief/full details, and the selections are preserved.
Opening a new tab
There are many ways to open a new tab:
- Ctrl+T opens a new tab, keeping the current directory.
- Ctrl+Up arrow opens the folder or archive under the cursor in a new tab.
- Shift +Drive selection opens the drive in a new tab.
- Shift pressed when using the function "Directory Hotlist" (Ctrl+D) also opens the directory in a new tab.
- In the right click menu of a tab, you can duplicate the tab, or copy it to the opposite file panel.
- Drag multiple folders with the mouse to an empty space in the tab header. When you see a mouse cursor with a little arrow in the file symbol, the folders will be added as additional tabs! This way you can also copy or move to these tabs.
Switching between tabs
To switch between tabs, you can either click them with the mouse, or press Ctrl+Tab. Ctrl+Shift+Tab switches to the previous tab.
Other operations
The following operations are also supported:
- Close a tab: Ctrl+W, Click with the middle mouse button (or the wheel) on the tab, double click, right click menu
- Rearrange tabs: Simply by drag&drop to the desired position, even on the other panel.
- Save tabs to file or load from file: via the right click menu. Useful e.g. for project-oriented working.
appendtabs tabfile.tab  in the button bar appends the tabs saved in tabfile.tab.
opentabs tabfile.tab  in the button bar replaces the current tabs with the tabs saved in tabfile.tab.
Note: To change the tabs in both windows, you need to combine two tab files by hand, and then rename one of the sections from [activetabs] to [inactivetabs] .
- Rename and/or lock tabs (via right click menu): Allows to create fixed tabs, which cannot be deleted so easily, e.g. for often used directories. When you try to change the directory in such a tab, a new tab will be created automatically!
- The behaviour of folder tabs can be configured via the main configuration dialog<!--QuoteEnd--></td></tr></table><div class='postcolor'><!--QuoteEEnd-->
<!--QuoteBegin--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>Цитата </td></tr><tr><td id='QUOTE'><!--QuoteEBegin-->... написано ... можно открывать вместо двух сразу несколько файловых панелей.<!--QuoteEnd--></td></tr></table><div class='postcolor'><!--QuoteEEnd-->
Прямо так и написано? Изображение
Последний раз редактировалось Evgenych Сб май 29, 2004 12:46 pm, всего редактировалось 1 раз.
Evgenych
Сообщение Yury » Сб май 29, 2004 2:39 pm
ОК
Все заработало - Ура!!!
Только непонятно почему до этой фичи можно добраться по горячим клавишам и ничего нет в менюхах?
Yury
Сообщение Ajax » Сб май 29, 2004 3:21 pm
2Yury
Все есть.
Configuration -> Layout -> Folder Tabs
Сообщение Yury » Сб май 29, 2004 5:37 pm
Нашел!
Не догадался что это обзывается закладками.
Однако штука удобная.
Спасибо за помощь!!!
Yury
Сообщение Ajax » Сб май 29, 2004 5:57 pm
И впрямь... С чего это Гислер эти _хрени_* _закладками_ обозвал?
Надо было честно писать... что это... есть... ну, как их... вот...
__________________
* хрен - такое растение из семейства крестоцветных (между прочим, многолетнее!)
