<a href='http://www.Widok-files.piterprint.ru/tcmd601b1.zip' target='_blank'>http://www.Widok-files.piterprint.ru/tcmd601b1.zip</a>
<!--QuoteBegin--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE </td></tr><tr><td id='QUOTE'><!--QuoteEBegin-->19.11.03 Release Total Commander 6.01 beta 1
Fixed: No environment variables supported in path to main menu and language file
Fixed: Don't show tree button in background transfer manager - overwrite - rename dialog (caused hang)
Fixed: Background transfer manager: remove item from list if "-" button is used to skip current transfer
Fixed: Don't show two errors when aborting background transfer manager
Fixed: Couldn't create multipart ACE SFX archives
Fixed: 16-bit version: Ctrl+Q no longer working
Fixed: Hourglass cursor shown after checking single archive with Alt+Shift+F9
Fixed: The Pause button didn't work for FTP uploads via a HTTP proxy
Fixed: Apply button not enabled in configuration-copy/delete in field "drives on same disk"
Fixed: "Show admin shares" no longer working on Windows NT
Fixed: Check for absence of "Microsoft Sans Serif" font failed, resulting in the wrong font (e.g. on WinNT4)
Fixed: Ctrl+Q with IEView plugin no longer working on dirs
Fixed: "Duplicate this tab" wasn't working for search results, now it works at least for the current tab
Fixed: cm_editpath not working in brief view when other than first column was active
Fixed: invalid floating point operation in lister when pressing F2 on very short file if this file was changed<!--QuoteEnd--></td></tr></table><span class='postcolor'><!--QuoteEEnd-->
