Эволюция программиста
Сообщение Леха » Вс апр 20, 2003 12:04 pm
High School/Jr.High
10 PRINT "HELLO WORLD"
20 END
First year in College
program Hello(input, output)
begin
writeln('Hello World');
end.
Senior year in College
(defun hello
(print
(cons 'Hello (list 'World))))
New professional
#include
void main(void)
char *message[] = {"Hello ", "World"};
int i;
for(i = 0; i < 2; ++i)
printf("%s", message[i]);
printf("n");
Seasoned professional
#include
#include
class string
private:
int size;
char *ptr;
public:
string() : size(0), ptr(new char('')) {}
string(const string &s) : size(s.size)
ptr = new char[size + 1];
strcpy(ptr, s.ptr);
~string()
delete [] ptr;
friend ostream &operator <<(ostream &, const string &);
string &operator=(const char *);
ostream &operator<<(ostream &stream, const string &s)
return(stream << s.ptr);
string &string::operator=(const char *chrs)
if (this != &chrs)
delete [] ptr;
size = strlen(chrs);
strcpy(ptr, chrs);
return(*this);
int main()
string str;
str = "Hello World";
cout << str << endl;
return(0);
Master Programmer
uuid(2573F8F4-CFEE-101A-9A9F-00AA00342820)
library LHello
// bring in the master library
importlib("actimp.tlb");
importlib("actexp.tlb");
// bring in my interfaces
#include "pshlo.idl"
uuid(2573F8F5-CFEE-101A-9A9F-00AA00342820)
cotype THello
interface IHello;
interface IPersistFile;
exe,
uuid(2573F890-CFEE-101A-9A9F-00AA00342820)
module CHelloLib
// some code related header files
importheader(
#include
#include
#include
#include "thlo.h"
#include "pshlo.h"
#include "shlo.hxx"
#include "mycls.hxx"
int CHello:cObjRef = 0;
CHello::CHello(IUnknown *pUnk) : CHelloBase(pUnk)
cObjRef++;
return;
HRESULT __stdcall CHello::PrintSz(LPWSTR pwszString)
printf("%wsn", pwszString);
return(ResultFromScode(S_OK));
CHello::~CHello(void)
// when the object count goes to zero, stop the server
cObjRef--;
if( cObjRef == 0 )
PulseEvent(hEvent);
return;
#include
#include
#include "pshlo.h"
#include "shlo.hxx"
HANDLE hEvent;
int _cdecl main(
int argc,
char * argv[]
ULONG ulRef;
DWORD dwRegistration;
CHelloCF *pCF = new CHelloCF();
hEvent = CreateEvent(NULL, FALSE, FALSE, NULL);
// Initialize the OLE libraries
CoInitiali, NULL);
CoInitializeEx(NULL, COINIT_MULTITHREADED);
CoRegisterClassObject(CLSID_CHello, pCF, CLSCTX_LOCAL_SERVER,
REGCLS_MULTIPLEUSE, &dwRegistration);
// wait on an event to stop
WaitForSingleObject(hEvent, INFINITE);
// revoke and release the class object
CoRevokeClassObject(dwRegistration);
ulRef = pCF->Release();
// Tell OLE we are going away.
CoUninitialize();
return(0); }
extern CLSID CLSID_CHello;
extern UUID LIBID_CHelloLib;
CLSID CLSID_CHello = { /* 2573F891-CFEE-101A-9A9F-00AA00342820 */
0x2573F891,
0xCFEE,
0x101A,
{ 0x9A, 0x9F, 0x00, 0xAA, 0x00, 0x34, 0x28, 0x20 }
UUID LIBID_CHelloLib = { /* 2573F890-CFEE-101A-9A9F-00AA00342820 */
0x2573F890,
0xCFEE,
0x101A,
#include
#include
#include
#include
#include
#include "pshlo.h"
#include "shlo.hxx"
#include "clsid.h"
int _cdecl main(
int argc,
char * argv[]
HRESULT hRslt;
IHello *pHello;
ULONG ulCnt;
IMoniker * pmk;
WCHAR wcsT[_MAX_PATH];
WCHAR wcsPath[2 * _MAX_PATH];
// get object path
wcsPath[0] = '';
wcsT[0] = '';
if( argc 1) {
mbstowcs(wcsPath, argv[1], strlen(argv[1]) + 1);
wcsupr(wcsPath);
else {
fprintf(stderr, "Object path must be specifiedn");
return(1);
// get print string
if(argc 2)
mbstowcs(wcsT, argv[2], strlen(argv[2]) + 1);
else
wcscpy(wcsT, L"Hello World");
printf("Linking to object %wsn", wcsPath);
printf("Text String %wsn", wcsT);
hRslt = CoInitializeEx(NULL, COINIT_MULTITHREADED);
if(SUCCEEDED(hRslt)) {
hRslt = CreateFileMoniker(wcsPath, &pmk);
hRslt = BindMoniker(pmk, 0, IID_IHello, (void **)&pHello);
// print a string out
pHello->PrintSz(wcsT);
Sleep(2000);
ulCnt = pHello->Release();
else
printf("Failure to connect, status: %lx", hRslt);
CoUninitialize();
return(0);
Apprentice Hacker
#!/usr/local/bin/perl
$msg="Hello, world.n";
if ($#ARGV >= 0)
while(defined($arg=shift(@ARGV)))
$outfilename = $arg;
open(FILE, ">" . $outfilename) || die "Can't write $arg: $!n";
print (FILE $msg);
close(FILE) || die "Can't close $arg: $!n";
} else {
print ($msg);
1;
Experienced Hacker
#include
#define S "Hello, Worldn"
main(){exit(printf(S) == strlen(S) ? 0 : 1);}
Seasoned Hacker
% cc -o a.out ~/src/misc/hw/hw.c
% a.out
Guru Hacker
% cat
Hello, world.
^D
AXE System programmer
LL0:
.seg "data"
.seg "text"
.proc 04
.global _main
_main:
!#PROLOGUE# 0
sethi %hi(LF26),%g1
add %g1,%lo(LF26),%g1
save %sp,%g1,%sp
!#PROLOGUE# 1
.seg "data1"
L30:
.ascii "Hello, World12"
.seg "text"
.seg "data1"
L32:
.seg "text"
set L32,%o0
call _strlen,1
nop
mov %o0,%i5
set L30,%o0
call _printf,1
nop
cmp %o0,%i5
bne L2000000
nop
mov 0,%o0
b L2000001
nop
L2000000:
mov 0x1,%o0
L2000001:
call _exit,1
nop
LE26:
ret
restore
LF26 = -96
LP26 = 96
LST26 = 96
LT26 = 96
.seg "data"
0000000 0103 0107 0000 0060 0000 0020 0000 0000
0000020 0000 0030 0000 0000 0000 0054 0000 0000
0000040 033f ffff 8200 63a0 9de3 8001 1100 0000
0000060 9012 2000 4000 0000 0100 0000 ba10 0008
0000100 1100 0000 9012 2000 4000 0000 0100 00 ba10 0008
0000100 1100 0000 9012 2000 4000 0000 0100 0000
0000120 80a2 001d 1280 0005 0100 0000 9010 2000
0000140 1080 0003 0100 0000 9010 2001 4000 0000
0000160 0100 0000 81c7 e008 81e8 0000 0000 0000
0000200 4865 6c6c 6f2c 2057 6f72 6c64 0a00 4865
0000220 6c6c 6f2c 2057 6f72 6c64 0a00 0000 0000
0000240 0000 000c 0000 0608 0000 006e 0000 0010
0000260 0000 060b 0000 006e 0000 0014 0000 0286
0000300 ffff ffec 0000 0020 0000 0608 0000 0060
0000320 0000 0024 0000 060b 0000 0060 0000 0028
0000340 0000 0186 ffff ffd8 0000 004c 0000 0386
0000360 ffff ffb4 0000 0004 0500 0000 0000 0000
0000400 0000 000a 0100 0000 0000 0000 0000 0012
0000420 0100 0000 0000 0000 0000 001a 0100 0000
0000440 0000 0000 0000 0020 5f6d 6169 6e00 5f70
0000460 7269 6e74 6600 5f73 7472 6c65 6e00 5f65
0000500 7869 7400
0000504
% axe_generate -f system.uhdl
Application 'Exchange' generated
2324042350000000 source code lines
No Errors detected.
Hardware retrieval...done OK
Certification Test...done OK
Packing..............done OK
Delivery.............done OK
Application 'Exchange' delivered to customer
23456000 bytes/sec.
End processing, 2345 seconds.
Ultra high level programmer
system.uhdl :
SYSTEM
CREATE ScreenWin
SIZE 20000000/Unit=One
DESTINATION Order.dest[One]
OUTPUT CHARACTER['Hello world']
END
END
New Manager
20 END
Middle Manager
mail -s "Hello, world." bob@b12
Bob, could you please write me a program that prints
"Hello, world."? I need it by tomorrow.
^D
Senior Manager
% zmail all
I need a "Hello, world." program by this afternoon.
Chief Executive
% message
message: Command not found
% pm
pm: Command not found
% letter
letter: Command not found.
% mail
To: ^X ^F ^C
> help mail
help: Command not found.
>what
what: Command not found
>need help
need: Command not found
> damn!
!: Event unrecognized
>exit
exit: Unknown
>quit
% logout
Bipppp ! Mrs. Thompson? Please page Tommy for me. NOW!
Леха
Сообщение dAnIK SeNT » Сб июн 28, 2003 3:46 pm
High School/Jr.High
  20 END
    begin
    end.
  (defun hello
     (print
New professional
  #include <stdio.h>
  void main(void)
    int i;
    printf("\n");
  #include <iostream.h>
  #include <string.h>
    class string
    private:
      int size;
      char *ptr;
    public:
      string() : size(0), ptr(new char('<!--POST BOX-->')) {}
        strcpy(ptr, s.ptr);
      ~string()
        delete [] ptr;
      if (this != &chrs)
        delete [] ptr;
        strcpy(ptr, chrs);
      return(*this);
    int main()
      string str;
      return(0);
Master Programmer
    library LHello
        cotype THello
     interface IHello;
    exe,
    module CHelloLib
        importheader(<windows.h );
        importheader(<ole2.h );
        importheader(<except.hxx );
        importheader("pshlo.h");
        importheader("shlo.hxx");
        importheader("mycls.hxx");
        // needed typelibs
        importlib("thlo.tlb");
        uuid(2573F891-CFEE-101A-9A9F-00AA00342820),
        aggregatable
        coclass CHello
     cotype THello;
    #include "ipfix.hxx"
    extern HANDLE hEvent;
    class CHello : public CHelloBase
    public:
        IPFIX(CLSID_CHello);
        CHello(IUnknown *pUnk);
        ~CHello();
        HRESULT  __stdcall PrintSz(LPWSTR pwszString);
    private:
        static int cObjRef;
    #include <windows.h>
    #include <ole2.h>
    #include <stdio.h>
    #include <stdlib.h>
    #include "thlo.h"
    #include "pshlo.h"
    #include "shlo.hxx"
        cObjRef++;
        return;
        printf("%ws\n", pwszString);
    cObjRef--;
    if( cObjRef == 0 )
        PulseEvent(hEvent);
    return;
    #include <ole2.h>
    #include "pshlo.h"
    #include "shlo.hxx"
    HANDLE hEvent;
     int _cdecl main(
    int argc,
    char * argv[]
    ULONG ulRef;
    CoInitiali, NULL);
    CoUninitialize();
    return(0); }
        0x2573F891,
        0xCFEE,
        0x101A,
        0x2573F890,
        0xCFEE,
        0x101A,
    #include <ole2.h>
    #include <stdlib.h>
    #include <string.h>
    #include <stdio.h>
    #include "pshlo.h"
    #include "shlo.hxx"
    #include "clsid.h"
    int _cdecl main(
    int argc,
    char * argv[]
    HRESULT  hRslt;
    IHello        *pHello;
    ULONG  ulCnt;
    IMoniker * pmk;
    // get object path
    wcsPath[0] = '<!--POST BOX-->';
    wcsT[0] = '<!--POST BOX-->';
    if( argc   1) {
        wcsupr(wcsPath);
    else {
        fprintf(stderr, "Object path must be specified\n");
        return(1);
    // get print string
    if(argc   2)
    else
    printf("Linking to object %ws\n", wcsPath);
    printf("Text String %ws\n", wcsT);
     Sleep(2000);
        else
        CoUninitialize();
    return(0);
Apprentice Hacker
  $msg="Hello, world.\n";
  if ($#ARGV >= 0) {
    while(defined($arg=shift(@ARGV))) {
      open(FILE, ">" . $outfilename) || die "Can't write $arg: $!\n";
      print (FILE $msg);
      close(FILE) || die "Can't close $arg: $!\n";
  } else {
    print ($msg);
  1;
Experienced Hacker
  #include <stdio.h>
  #define S "Hello, World\n"
Seasoned Hacker
  % a.out
Guru Hacker
  % cat
  Hello, world.
  ^D
  LL0:
          .seg    "data"
          .seg    "text"
          .proc 04
          .global _main
  _main:
          !#PROLOGUE# 0
          sethi   %hi(LF26),%g1
          save    %sp,%g1,%sp
          !#PROLOGUE# 1
          .seg    "data1"
  L30:
          .ascii  "Hello, World2<!--POST BOX-->"
          .seg    "text"
          .seg    "data1"
  L32:
          .seg    "text"
          set     L32,%o0
          call    _strlen,1
          nop
          mov     %o0,%i5
          set     L30,%o0
          call    _printf,1
          nop
          cmp     %o0,%i5
          bne     L2000000
          nop
          mov     0,%o0
          b       L2000001
          nop
  L2000000:
          mov     0x1,%o0
  L2000001:
          call    _exit,1
          nop
  LE26:
          ret
          restore
         LF26 = -96
          LP26 = 96
          LST26 = 96
          LT26 = 96
          .seg    "data"
  0000500 7869 7400
  0000504
  No Errors detected.
  23456000 bytes/sec.
  system.uhdl :
  SYSTEM
    CREATE ScreenWin
    END
  END
New Manager
  20 END
Middle Manager
  ^D
Senior Manager
  % zmail all
Chief Executive
    % message
    % pm
    % letter
    % mail
    To: ^X ^F ^C
      help mail
    >what
    >need help
      damn!
    >exit
    exit: Unknown
    >quit
    % logout
Источник - винт <!--emo&:)-->Изображение<!--endemo-->
Сообщение MAPA3bM » Вс июн 29, 2003 11:05 pm
Где-то раньше уже видел...
MAPA3bM
Сообщение Esquire » Пн июн 30, 2003 12:51 pm
C00L
<span style='font-size:8pt;line-height:100%'><span style='color:grey'>Воистину нет ничего, кроме подлинной цели настоящего мгновения... </span>
<span style='color:blue'>если человек глубоко это осознал, он должен, не задерживаясь, переходить от одного переживания к другому.</span></span>
Esquire
Сообщение Strike » Ср июл 02, 2003 6:18 pm
По жанру напоминает "Эволюцию доктора Полларда" Эдмонта Гамильтона <!--emo&:)-->Изображение<!--endemo-->
Strike
Сообщение NickFW » Сб апр 24, 2004 2:46 am
объеденил 2 темы...
Вернуться в Юмор
